Question about Maytag MSD2756G Side by Side Refrigerator
Ice-maker problem i bought the fridge new gsl25jfpbs, but never used the ice-maker.. 3 years later i hook up water to it and problems... i turn the water on and the ice-maker makes one set of ice cubes, dumpeds them in the bucket and them refills the tray, BUT the wtaer doesn't turn off and floods onto the floor... if i turn the water off,, it makes ice-cubes again and truning the water back on will flood the fridge again..... seems like it makes ice, but there is nothing that turns off the water flow hen the tray is full ??? davey 8186455008 have maytag refrige never hooked up ice maker hooked it up yesterday get water to door dispenser no water coming into ice tray when press for ice here noise like it wants to drop ice but get nothing
  • 113 Answers
If the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Posted on Apr 29, 2009
2 Suggested Answers
6ya staff
SOURCE:
robert samples
  • 1314 Answers
SOURCE: ice-maker problem
ok do you have a meter a volt meter ill tell you a better way to do it go to the back of the refrigerator and un plug the water valves then open the freezer door turn on the water if you hear the water running replace the valves if you don't replace the ice maker module the range for pressure is 30-120psi the valve just might be sticking from being dry for so long
Posted on Feb 01, 2008
My BI95 ice maker freezes and has water flow, the mould maker fills, the water continues to run into the bucket and it freezes solid. I changed the mould maker and water valve. The problem remains
If water keeps running after the fill cycle is usually indicates a bad fridge inlet valve. This valve controls the amount of water going into your icemaker. It is found where the water line goes into the fridge, usually in the back of the fridge at the bottom. You would need to cut the power to the fridge, turn off the water supply going into the fridge and remove a panel to get to it. You can check out online what a fridge water inlet valve looks like so you can identify it. It usually has 1-2 water lines going into it and 1-2 wire harnesses attached. You can buy new ones at a appliance parts store or online.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_b814bade9ade93ea
Sep 28, 2015 | U-Line Icemaker
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
LG LFX23961ST with error code ER IF
could be bad fan. sometimes the sensors on the them go bad
Apr 22, 2010 | LG LFX23961ST Stainless Steel Bottom...
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice maker not working, ice maker is on, water dispenser is working (supply working)
I have the same make and model. I had to replace the Motherboard. I bought it online $100 and it is really easy to replace. I heard from my neighbors who had the same fridge that they got the $100 refund from GE because it was a manufacturing defect.
Sep 08, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerator with ice maker but no hook up
just make sure the lever on the ice maker is up and locked or the switch on the ice maker is off ( i dont know what model you have) but thats all you need to do , if at any thinr it gets turned on dont worry it not a problem it will just cost you a little nore to run . no damage to the fridge or ice maker .. please rate this answer , i am new here and it will be a great help thanks and good luck with your fridge
Jan 16, 2009 | Maytag Refrigerators
Fridge Leak
hi thanks for the question the water in the crisper is caused by a clogged drain tube Pull the fridge away from the wall. remove back panel clean all coils find drain tube in drain tray and clean to inside of fridge thanks the appliance doc
Sep 29, 2008 | Refrigerators
Ice-maker problem
it will respond better if you fill it with scotch
Apr 16, 2017 | Refrigerators
Ice-maker problem
Jan 31, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
315 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
