Orion HCCA-D2400 Car Audio Amplifier Logo
Posted on Apr 29, 2009
Yellow light starts blinking when i raise gain control
When i raise the gain control control on the amp the yellow light starts blinking why is that
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on May 01, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
Helped
4895
Points
21
This might be because the subs might not be able to handle the power that the amp is putting out. this could also be a peak power light. try turning the volume down on the head unit, and see if it still does it.
Master volume not registering at correct level. Profx12
This unit will require an amp. I have set up several mixers and I
do not watch output level numbers, you can get desired volume using amp. It does no good to drive input levels high output levels high and the turn down amp. Lower your inputs so no light flashes set master gain to -6 output and then raise amp volume. I have set up 16 mic mixer set individual levels and the feed to main mixer and controlled levels with one fader. I have taken mixes from main mixer to another mixer to control audio on video feed. A good band does not let member's set their levels . the audio person set levels, bad bands have members to set own level with resultant a mess that gets louder and produces sub par event. Remember good bands sound good and bad bands only sound louder, and bad
2015 jeep Grand Cherokee climate control cup holder lights. what is fuse #?
Hi, I have a 2014 Grand Cherokee Laredo E. There is a white line at the top of the cupholders that I would expect to light up with the ambient lighting, but does not light up in my truck. Does it light up in others? Is there a way to get lighting in there?
Thanks,
2015 Jeep Grand Cherokee fuse layout Power Distribution Center The Power Distribution Center (PDC) is located in the engine compartment near the battery.
F03 60 Amp Yellow - Radiator Fan
F05 40 Amp Green - Compressor for Air Suspension - If Equipped
F06 40 Amp Green - Anti-lock Brakes/Electronic Stability Control Pump
F07 40 Amp Green - Starter Solenoid
F08 20 Amp Blue - Emission Sensors (Diesel engine only)
F09 30 Amp Pink - Diesel Fuel Heater (Diesel engine only)
F10 40 Amp Green - Body Controller/Exterior Lighting #2
F11 30 Amp Pink - Trailer Tow Electric Brake - If Equipped
F12 40 Amp Green - Body Controller #3/Power Locks
F13 40 Amp Green - Blower Motor Front
F14 40 Amp Green - Body Controller #4/Interior Lights #2
F17 30 Amp Pink - Headlamp Washer- If Equipped
F19 20 Amp Blue - Headrest Solenoid- If Equipped
F20 30 Amp Pink - Passenger Door Module
F22 20 Amp Blue - Engine Control Module
F23 30 Amp Pink - Interior Lights #1
F24 30 Amp Pink - Driver Door Module
F25 30 Amp Pink - Front Wipers
F26 30 Amp Pink - Anti-lock Brakes/Stability Control Module/Valves
F28 20 Amp Blue - Trailer Tow Backup Lights - If Equipped
F29 20 Amp Blue - Trailer Tow Parking Lights - If Equipped
F30 30 Amp Pink - Trailer Tow Receptacle - If Equipped
F32 30 Amp Pink - Drive Train Control Module
F34 30 Amp Pink - Slip Differential Control
F35 30 Amp Pink - Sunroof - If Equipped
F36 30 Amp Pink - Rear Defroster
F37 25 Amp Clear - Rear Blower Motor - If Equipped
F38 30 Amp Pink - Power Inverter 115V AC - If Equipped
F39 30 Amp Pink - Power Liftgate - If Equipped
F40 - 10 Amp Red Daytime Running Lights/Headlamp Leveling
F42 - 20 Amp Yellow Horn
F44 - 10 Amp Red Diagnostic Port
F46 - 10 Amp Red Tire Pressure Monitor - If Equipped
F49 - 10 Amp Red Integrated Central Stack/Climate Control
F50 - 20 Amp Yellow Air Suspension Control Module - If Equipped
F51 - 15 Amp Blue Ignition Node Module/Keyless Ignition/Steering Column Lock
F52 - 5 Amp Tan Battery Sensor
F53 - 20 Amp Yellow Trailer Tow - Left Turn/Stop Lights - If Equipped
F55 - 10 Amp Red DTV/DSRC
F56 - 15 Amp Blue Additional Content (Diesel engine only)
F57 - 15 Amp Blue HID Headlamps LH - If Equipped
F59 - 10 Amp Red Purging Pump (Diesel engine only)
F60 - 15 Amp Blue Transmission Control Module
F61 - 10 Amp Red Transmission Control Module/PM Sensor (Diesel engine only)
F62 - 10 Amp Red Air Conditioning Clutch
F63 - 20 Amp Yellow Ignition Coils (Gas), Urea Heater (Diesel)
F64 - 25 Amp Clear Fuel Injectors/Powertrain
F66 - 10 Amp Red Sunroof/Passenger Window Switches/Rain Sensor
F67 - 15 Amp Blue CD/DVD/Bluetooth Hands-free Module - If Equipped
F68 - 20 Amp Yellow Rear Wiper Motor
F69 - 15 Amp Blue Spotlight Feed - If Equipped
F70 - 20 Amp Yellow Fuel Pump Motor
F71 - 30 Amp Green Audio Amplifier
F73 - 15 Amp Blue HID Headlamp RH - If Equipped
F74 - 20 Amp Yellow Brake Vacuum Pump - If Equipped
F76 - 10 Amp Red Anti-lock Brakes/Electronic Stability Control
F77 - 10 Amp Red Drivetrain Control Module/Front Axle Disconnect Module
F78 - 10 Amp Red Engine Control Module/Electric Power Steering - If Equipped
F80 - 10 Amp Red Universal Garage Door Opener/Compass/Anti-Intrusion Module
F81 - 20 Amp Yellow Trailer Tow Right Turn/Stop Lights
F82 - 10 Amp Red Steering Column Control Module/Cruise Control
F83 - 10 Amp Red Fuel Door
F84 - 15 Amp Blue Switch Bank/Instrument Cluster
F85 - 10 Amp Red Airbag Module
F86 - 10 Amp Red Airbag Module
F87 - 10 Amp Red Air Suspension - If Equipped/Trailer Tow/Steering Column Control Module
F88 - 15 Amp Blue Instrument Panel Cluster
F90/F91 - 20 Amp Yellow Power Outlet (Rear seats) Selectable
F92 - 10 Amp Red Rear Console Lamp - If Equipped
F93 - 20 Amp Yellow Cigar Lighter
F94 - 10 Amp Red Shifter/Transfer Case Module
F95 - 10 Amp Red Rear Camera/ParkSense®
F96 - 10 Amp Red Rear Seat Heater Switch/Flashlamp Charger - If Equipped
F97 - 20 Amp Yellow Rear Heated Seats & Heated Steering Wheel - If Equipped
F98 - 20 Amp Yellow Front Heated Seats - If Equipped
F99 - 10 Amp Red Climate Control/Driver Assistance Systems Module
F100 - 10 Amp Red Active Damping - If Equipped
F101 - 15 Amp Blue Electrochromatic Mirror/Smart High Beams - If Equipped
F103 - 10 Amp Red Cabin Heater (Diesel Engine Only)/Rear HVAC
F104 - 20 Amp Yellow Power Outlets (Instrument Panel/Center Console)
All arctic air personal cooler lights blinking, the higher I turn up the fan the faster they blink even the power button anybody no why ?
I just got my artic air personal cooler & followed all directions and immediately started blinking yellow. any way to reset?
My R15 v2 YZF engine light blinks 10 times firsts 5 blinks slow rest very fast bike tends to stop whenever it appears n stop but when the light is on upper the bikes dont stop above 90 km/hr not stop
Yamaha yellow blinking light start Motorcycles Questions ...
www.fixya.com > ... > Tags > yellow blinking light start > Motorcycles
Ad. Question about 1997 YZF 750 R ... oil light blinking on 2004 yamaha r1 oil lightblinks 10 times stops then blinks 10 ... My yamaha r15 v2 I drive to bike after sometimes yellow engine light on aftersometime I light on to yellow engine light of.
Yamaha blinking yellow light Questions & Answers - Fixya
www.fixya.com > Forum > Tags > blinking yellow light
oil light blinking on 2004 yamaha r1 oil light blinks 10 times stops then blinks 10 times ... Question about 2008 YZF-R15 ... My yamaha r15 v2 I drive to bike after sometimes yellow engine light on aftersometime I light on to yellow engine light of.
[Ownership Thread]: Yamaha YZF-R15 - xBhp.com
www.xbhp.com/talkies/.../4854-yamaha-yzf-r15-1951-print.html
Jul 11, 2013 - 4 posts - ‎3 authors
2months back i got this problem while riding the engine goes off, but ... of heavy traffic after transporting it from my home town. then it works fine and all of a sudden i find the bike engine light blinking. it reads '42'. then after showing it to ... the ECU alone wil cost me to 10k. and obviously it is very expensive ...
Yamaha YZF-R15 version 2.0 - xBhp.com
www.xbhp.com/.../20138-yamaha-yzf-r15-version-2-0-a-786-print.html
Nov 26, 2013 - According to me the problem of chain with my bike is because i ... list about the required changes at 10k kms like Fork oil change and ... On switching on the ignition, the engine malfunction light, the orange(?) ... From your description that a longblink coupled with 3-4 short blinks it .... All times are GMT +6.5.
Jan 27, 2016 • Motorcycles
What would cause a 2004 saturn ion 2.2 , yellow engine light to blink constantly?
The vehicle has NEVER been properly diagnosed
& any and all issues even found
If it was,they would let you know & you could pay
to have them corrected
You never replace a converter, until you take care of fuel
& misfires problems,now the new one will over heat & be ruined
Have to use professional tools ,road test & component test, to
even find a problem
All your issues would require 3 days of work, to get mostly through
the diagnostics & some of the fixes
Normal Cycle blink and washer won't start
check the float switch. make sure its operational. make sure you hear the solenoid click when you raise it up. you may just need to replace the control
8helpful
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
How to tune properly
make sure your speakers are wired to the amp with correct ohm load, turn gain, bass boost all the way down on amp, zero out your equilizer on the cd player and turn it all the way down then start raising volume on cd player., when u can start hearing music thru the subwoofers adjust the cd player volume till the sound from your subs is at its peak without any distortion. then start raising the gain on your amp till you are happy with the sound. It gives you the optimal signal strength coming from the cd player and the smoothest sound.
Yellow traction & ABS lights come on when external temp is -3 Degrees C.. is it supposed to do that?
no...
these are controlled by wheel sensors, seldom do both go if ever.
based on the fact that the issue is climate related, you may check for a wet ECU...
read below
the ecu compartment is under the windshield on the passenger side on E36
you gain acess to it under the hood....
this compartment gets wet, the ecu lays on a flat surface in that
compartment.
the bottom side of the circuit board gets wet and starts corrosion.
remove the ecu, take the bottom plate off, clean the bottom of the circuit
board with alcohol and a soft tooth brush.
you should be able to see the signs of corrosion or conductive build up.
this gunk bridges solder points doing all sort s of wierd things to your
car, including false sensor readings from asc/abs controllers and other
sensors....
all the way to engine failure and worst case burnt and shorted wiring
harness.
I'm on my 3rd ecu, took me and the repair boys a few years to figure this
one out.
BTW: i would get that ecu mounted above that flat surface, use some sort
of standoff to raise it so that it is not laying in the wet.
Yellow light start blinking
do you have a power cap, if not your amps not getting the power it
wants what size wire you running should be 2gage
Top Orion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
