try resting your tv. power off it press and hold av select botton and then power on your tv wait few minutes and it will rest your tv.... if not used the same wy holding menu botton instead.
The power supply needs repaired NOW. I suggest you do not play it---unplug it ---and take it in for service. If you continue to play it you will price yourself into a new tv.
the power supply has failed. On the power supply there are 4 caps which go bad because of the low value. if you want to give it a shot at repair replace them if not replac the power supply
press and hold the tv botton on you dish remote till all the lights light up release the tv botton it should stay flashing then hit the larger of the two red power bottons next you will need to hit the up arrow one at a time till the tv shuts off when the tv shuts off you then hit the # botton at the bottom you wiil see the tv botton flash your code will then be saved
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
