Microsoft Halo: Combat Evolved for Windows Logo
v
vibhubhasin Posted on Oct 31, 2013
Config txt - Microsoft Halo: Combat Evolved for Windows
1helpful
Cisco Unified Communications 500 Series reset password with out losing my configuration
if you are talking about your enable password you will have 2 choices which are a factory reset or evoke ROMMON. The simplest way is to backup your running config via TFTP or do a #show run and copy and paste the whole config to a txt file and then reset to factory default and then just load(or paste) that config and then do a #copy run start.
tip
Download Files From Rapidshare To Windows Mobiles With wmDownloader
Whenever you need to download any file online from various softwares, you have to keep your PCs on till the download is complete. And in case you need to go somewhere and turn off your PCs, the downloading stops there and then. Also you might not want to keep your computer running behind you for personal reasons or for the sake of power-cut when you are not there. wmDownloader v0.20 is the solution to all these problems. This application allows you to easily download files from One-Click-Hosters like rapidshare.
It can be used to download your files overnight without the use of PC, but remember to plug your PocketPC to charger. Turning of not cheap GPRS data connection in case of WiFi lost connection is recommended
HOW TO INSTALL/USE THIS APP? After first start go to “Config” tab, select destination folder for your files and click “Save”. Now you can add files in “Files” tab or by editing file “files.txt” and then reloading it using “Menu->Reload files.txt”.
When you added some files you can start the download process. Files will be removed automatically from the list after download.
on Mar 05, 2010 • Cell Phones
3helpful
How can we change from black bar sensor printing to using the gap between labels on a Zebra QL320 plus?
First you need to send below file to the printer via Vista Label
Printer >> 1 Send File
Save this file as gapsen.txt:
! DF CONFIG.SYS
! UTILITIES
GAP-SENSE
PRINT
To save this as default setting, send below script (save as setting.txt)
^XA ^JUS ^XZ
2helpful
My halo software is not working
Cannot find 'C:\Program Files\Windows NT\config.txt'
2answers
Hp paviliondv2050us wont start
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
2helpful
How Send EPL2 commands to USB
Use the Zebra ZUD driver. Latest version V5.5.7.25 (Download from Zebra website). When driver is installed, go to printer & Faxes folder and double-click on the installed printer icon.
Click Printer/properties/printer/advanced (+)/tools (Click on tools) This opens a text box. Type commands in here and send directly to printer. E.G type U click send and it will print a config sheet.
This definately works.
4helpful
2answers
On samsung alias - how do I get the parenthesis? It's on the same key as # and T.....
I don't think you're supposed to get the parenthesis that way. I think that's for when you have the phone in the Portrait configuration and you use the calculator or something like that.
You can access the parenthesis by pressing the lower left soft key (while in txt mode, landscape config). Change your typing mode from Abc to Symbol and browse through the symbols.
Mobile fails to start while loading config.txt. The phone just switches off.
Download HP Universal Bootloader and reinstall the OS. I did it. It works fine.
4helpful
4answers
Configuration Wap
try this
Goto menu>Browser>Profile Settings>
Profile name : Rogers ( u can pick waht ever for this name )
Home Url : http://mymobilehomepage.rogers.com/
Bearer : GPRS Only
Proxy : Enable
Now last step is to go into GPRS Settings
Ip address : 172.25.0.107
Port : 80
Apn : goam.com
Login Id: wapuser1
Password : wap
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
