Question about H20 Bolt Flash 4G USB
After downloaded I get a message that a cable is unplugged cant' get it to work
Posted by Claribel Santos on
Brian Sullivan
  • H20 Master
  • 27,725 Answers
Which operating system ?
Posted on Feb 11, 2014
I replaced the hard drive because of the click of death. When I booted the cpu, I got a error message saying, system boot failure, install disk press enter. I place recovery disk in and disk started to...
You should check if your PSU is providing enough power to the hard drive. In case the hard drive requires more power, you should either replace it or get a better PSU.
Consult a professional for best results.
Jan 01, 2011 | HP Compaq Presario SR1720NX (EL435AA) PC...
Hi, Im getting a message that there could be problems with my network adapters so I cant access the internet, what should I do?
Hi, Unplug your Modem/Router for 10 seconds, let it start up, if this doesnt work try using an Ethernet cable and plug it in directly (Wired). let me know, thanks. Mark
May 03, 2010 | Toshiba Computers & Internet
LG KU990i Apps dont work
Is your phone a GSM or CDMA?
--RescueTechLA
Dec 04, 2009 | LG KU990 Viewty
NIC blinks on then off for longer run lines
You need to update the firmware of the router then hard reset it.
Download the router's firmware at www.linksys.com/download
After updating the firmware, you need to hard reset the router.
Press the reset button at the back of the router for 30 seconds then unplug the power for 30 secs then plug it back in. That should fix it.
Jul 01, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Place align paper on scanner glass
1,Unplug the USB cable
2,Place the allignment paper in the right bottom corner of the scanner glass
3,close the lid
4,Press the Start scan button
You will find the light blinking wait until it completes.
Then connect the cable and the issue will be resolved.
Hope works well for you
Apr 29, 2008 | HP PSC 750 All-In-One InkJet Printer
Using G630 but get "network cable unplugged" message
A little confusing this, it would not say 'Network cable unplugged' if windows was refering to your D-link wireless connection(It's wireless) The cable unplugged should be refering to your Wired Ethernet card, so there must be no cable connected at one or other end. You don't mention anything about what the wireless card is trying to connect to(eg Wireless modem/router or another wireless PC). Maybe your pc is getting confused as to whether you wish to connect wirelessly or wired, as it can only work through one IP Address at a time. i could be wrong, but you probably thought that they were working but only one was, you really need to explain why you are using both wired and wireless and what is connected to what, Please reply and hopefully it'll get sorted
Oct 26, 2006 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
H20 Bolt Flash 4G USB Logo
440 people viewed this question
Top H20 Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a H20 Computer and Internet Expert? Answer questions, earn points and help others
