Question about Kenmore Refrigerators
KENMORE ELITE REFRIGERATOR MODEL #795.77719700 LITES STAY ON WHEN DOORS ARE CLOSED,WHAT IS MY PROBLEM
Posted by SILVERFOX42553 on
Gere knutson
  • Kenmore Master
  • 842 Answers
Does the switch turn off the lights? If the doors are not installed correctly the switch wont work properly. Check the switch first to make sure that be depressing switch the will shut off lights, if this does work, check the doors as they make contact with switch. It is possible your door are too low to make contact with switch, I have seen this happen on GE units as the door dropped out of alignment of the switch contact.
Good Luck, hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Oct 31, 2013
Testimonial: "LITES STAY ON EVEN WHEN YOU DEPRESS SWITCHES"
  • SILVERFOX42553
    SILVERFOX42553 Nov 06, 2013
    UN SCREW BULBS AND SCREW BACK IN LITES OUT ,NOW SOFAR IT 7 DAYS
3 Related Answers
Anonymous
SOURCE: Light stays on when door is closed
The GE GSL22JFPH refrigerator door gets lower over time. When it gets low enough the light stays on when the door closes. There is a vertical bolt along the hinge line. Push down the hinged plastic "hinge cover" under the door right on the hinge line and you can get a wrench on the bolt to raise the door. I have to do this every 6 months/
Posted on Nov 30, 2006
Anonymous
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
Anonymous
  • 135 Answers
SOURCE: Kenmore Elite 795.7724 - Refrigerator Light Stays on
There is a factory update for this problem. You need a new control board and light parts.
Posted on Aug 27, 2009
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
Can't close the door on the water filter cabinet on my Kenmore Elite refrigerator
check to be sure you have the correct length filter in place, you may have one to long for the unit.
May 30, 2015 | Kenmore Refrigerators
What does Kenmore refrigerator error code er co mean?
I just did a google search. It seems that it is a communications error between the computer in the back of the refrigerator and the front panel display,. Some people have replaced the computer only to find that the problem stays. At least two have found that wires have broken in the front door.
The wires get flexed when the door is opened and closed.
Use your model number at the sears parts direct to see user manuals diagrams and parts lists. Link below.
http://www.searspartsdirect.com/
Sep 06, 2014 | Kenmore Elite 29 cu. ft. Grab-N-Go French...
Light stays on
Check the door frame for a protruding small lever that gets pushed down when the door closes. If one is visible, that should be the light switch, which probably went bad and needs to be replaced. Without a model # hard to say how the light are set to go off, but most use the above method, hope this helps.
Jan 30, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The light is remain lite and the plastic cover is malted.
The switch at the bottom of the door is bad, not turning the light off when the door is closed
Mar 01, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
HAVE A KENMORE REFRIGERATOR - MODEL # 253.60734407 - HAVING PROBLEM WITH THE MAIN DOOR STAYING CLOSED. IF I PLACE 2 LITES OF SODA ON THE DOOR. THE DOOR WON'T STAY SHUT. HAVE THERE BEEN ANY OTHER...
The main thing that makes a fridge door shut is that it falls shut because it is set at a slight angle with the front of the machine higher than the back. You may find the solution is as simple as making the fridge tip back a tiny bit more by turning the front feet clockwise to screw them out of the chassis and make them longer, causing the fridge to tip back a little and the door to fall shut as it should.
Jul 07, 2011 | Kenmore Refrigerators
If a kenmore elite door stays open does it turn off
yes it does for temp protection but when closed it should start back few min. after that.
Feb 22, 2011 | Kenmore 53642 / 53644 Side by Side...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Refrigerators Logo
199 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
