Question about Dell Inspiron 6400 Notebook
Error code 0123 on dell optiplex 360 - Dell Inspiron 6400 Notebook
5 Related Answers
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: I CANNOT FORMAT AND INSTALL A NEW OS
You RAM module may be faulty or needs reseating in the DIMM slot B. Reseat the both RAM modules then :-
Check the POST information as it boots up, the amount of install RAM should equal to the installed RAM (the total RAM could be 256Mb or 512Mb or 1Gb depends how much memory you purchased with the laptop) less 64 Mb or 128 Mb RAM which is used for video memory (depends upon your video card requirements).
Once you fix your RAM problems you should be able to reinstall Windows.
Posted on Mar 04, 2009
amafhh
  • 115 Answers
SOURCE: I have a dell inspiron 1520, today when I was
the problem is with your memory card as one memory module is not functioning which is in DIMM 1. you need to replace it.
because which playing music file as due to damage memory it takes time for buffering. and that is why you hear choppy sound. you can also run a test on memory. Restart the sys. and press F12 on blue Dell Logo. and goto BOOT TO UTILITY PARTITION and run a test on memory it will hardley take 5 mins. and it will give you the result.
Posted on Nov 04, 2009
conrad ingle
  • 9 Answers
SOURCE: my dell, latitude d630 gives
Remove and reinstall the memory for the error codes: 1000-0122
1000-0123
2000-0123
Please see the Service manual for instructions on how to remove and replace the memory.
Posted on Aug 06, 2011
SOURCE: reducing pc memory usage
I suggest you turn OFF all start up Items on your system, these use the PC memory up as soon as Windows Starts. Stat up Items can be disable from MSCONFIG, Starup and just unclick the Application that needs to stop from running during start-up, NOTE make sure you do not disable any windows application in MSCONFIG start up Items.
Posted on Apr 16, 2012
xmodule
Endre Nagy
  • 38 Answers
SOURCE: dell inspiron 6400 will not boot
It's something whit the LCD or LCD cabel. Take it to the service if you not so expert about taking a part the computers.
Posted on Dec 06, 2012
Colours 1,3, 4 on a dell optiplex 360
Try this...it looks like you're taking about how to connect cables that are visibly coloured..
http://www.manualslib.com/manual/553815/Dell-Optiplex-360.html?page=4#manual
Feb 06, 2014 | Dell OptiPlex 360 Desktop Computer
Memory march a text error code 2000-0123 msg memory intergrity text failed
Memory module (or modules) may have failed.
But worth checking that they are seated in the sockets correctly.
(Clean dust and fluff from M/B first)
Feb 04, 2014 | Dell Optiplex 380 Mini Tower Brand Intel...
Error 15 in dell optiplex 360
Error 15 does not appear to show up in any inquiries on Dell Optiplex errors. Could you specify where this error is being seen? Are you sure there are no more information or numbers to the error?
Oct 18, 2013 | Computers & Internet
Dell E1505 memory test march LR failed error code 2000 0123
try removing 1 memory stick at a time and see if it boots. hope this helps
Apr 05, 2013 | Dell Inspiron Computers & Internet
Como se resuelve el error code 3600:0123
Error Code 3600:0123 battery bay charger failed after installing video fan
if the video fan was not replaced recently then it either may need to be or at least it needs to have the fans on the bottom of the system blown out with compressed air.
Feb 16, 2013 | Dell Inspiron Mini 1012 Netbook...
How can we solve the problems of Ram code error 2000-0123
Sub out the ram memory one at a time if possible and see if there are any changes, if you have the one stick remove and reseat back in position, if no change, replace ram and upgrade to 1GB, "2X512MB" one for each slot.
Apr 21, 2012 | Dell Optiplex GX280 Desktop Computer -...
My dell, latitude d630 gives error 0123 on diagnostic and beeps. how do i solve this?
1000-0123
2000-0123
Aug 06, 2011 | Dell Studio XPS 1640 Notebook
Want audio Drivers for Windows Server 2008 64 bit. My Computer is Dell Optiplex 360
Try go to this link:
http://drivers.softpedia.com/downloadTag/Dell+Optiplex+360+Audio+Driver
Apr 11, 2010 | Dell OptiPlex 360 Desktop Computer
I HAVE NEW DELL OPTIPLEX 360 AND I HAVE DRIVERS & UTILITIES CD BUT CANNOT OPEN AS NORMAL MEANS AUTO RUN WHAT CAN I DO?
download n install "TweakUI"..this'll help..
http://www.winvistaclub.com/Ultimate_Windows_Tweaker.html
to b on safe hands, do the following:
2)hva licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
3) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
4) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeallthe unnecessary startup items from here..(if u can't find what toremove, post me/us in ur comment with all the items listed in each nevery tabs herein)..
5) remove all unnecessary software from add/remove programs..
6) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
7)disable the following:..
a)'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(un check on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
8) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
9) if problem persists try reinstalling os..
for better supervision, contact ur system admin/vendor....
Nov 16, 2009 | Dell OptiPlex 360 Desktop Computer
Dell Inspiron 6400 Notebook Logo
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
