Question about Bernina Activa 140
Help setting Viking Designer I machine for free motion quilting
I can't remember the touch screen commands for machine quilting with my viking designer I machine and i have misplaced my instruction book.
Can anyone help? i lowered the feed dogs and I have the machine threaded, but i need instructions about the touch screens. not sure I am setting it correctly.
  • Anonymous May 03, 2009
    Thanks Pam! I really appreciate your information!!
    Lisa
Pamsquilt
  • 201 Answers
I assume you are doing free motion quilting? Use the V Menu, choose the first stitch. If you are using the Q Sensor foot or the spring free motion foot, go into the Set menu, hit "More" twice then turn On for either the Q Foot or Free motion. Make sure you have Needle Down turned on (top right-hand button on the left side above the needle). You might need to loosen the top tension by one or two clicks - first screen of the Set menu, under the picture that looks like DNA. A Size 90 needle is probably best and if the quilt is difficult to move about you might like to either use the Sewing Advisor to set for Heavy fabric or lessen the upper presser foot pressure - Set menu once again, next picture after the DNA. I have never had to do this with my D1 but I know some other people have. Get back if things are not working well for you.
Pam
Posted on May 02, 2009
I can not remember how to set my Viking Designer 1 for free motion sewing
Drop the feed dogs and install a darning or free motion presser foot. Be sure to use a brand new needle. The stitch width should be set on zero. The stitch length really doesn't matter since you will be manipulating the material manually.
Then you will need to test on a scrap sandwich block made up of your fabric and batting to adjust the tension. Tension is appropriate when the upper and bobbin threads meet in the middle of the sandwich without any thread looping or pulling.
You may be able to find a manual by asking your local Viking dealer or search the internet for:
Make Model manual
Dec 01, 2016 | Sewing Machines
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
Viking designer 1
Hi, Free motion quilting is done with your programmed quilting stitches, Lower the feed dogs using the small white dial on the front of the machine behind the accessory tray, pick from one of the quilting stitches. they do make a free motion quilting tool ( I think they call it a hoop), but it just sets on top the material and helps you guide your material thru the machine. Hope this helps
Aug 29, 2014 | Husqvarna Sewing Machines
Why do the feed dogs reset while free motion quilting?
Your machine's feeddog drop control may loose or worn. Your authorized Viking repair dealer can fix the problem .
Jun 20, 2014 | Husqvarna Viking 1
My husqvarna designer 1 keypad doesnt work
It could be the Touch Screen. If it is a Designer 1. If it is a Designer II or Quilt Designer or #1 it could be the Dcard. Recommend it be checked by an Authorized Viking Dealer. You can find the nearest dealer from the Viking website - http://www.husqvarnaviking.com/us Click on the link Locate a Dealer.
May 21, 2014 | Husqvarna Sewing Machines
I am having trouble with the free motion on my Viking SE. I can feel the thread sticking up on the back and the top thread keeps breaking. I have tried changing thread (four times) and changing needle...
I presume you have set the machine for free motion quilting in the Menu? There are so many things that could be causing this, and so many variables for tweaking it to optimum performance. What foot are you using? What thread? What needle? What menu setting? Have you tried loosening the top thread tension? Bobbin tension? I will keep a lookout for further posts from you with a bit more info that we can start working on. I have a Designer1, not the SE, but have used an Se so will try my best to help.
Dec 15, 2010 | Husqvarna Designer I
Just bought a brand new Pfaff Quilt Expression 4.0 and the top thread keeps getting shredded and breaking while doing free motion quilting. I've checked threading diagrams, changed to four different...
this is a known issue with the pfaff.....i have just bought the machine and it has thread uptake issues...thread tension issues and it comes unthreaded by itself often...leaving globs of thread on the bottom stuck in the feed dogs and under the throat plate.....then the stitches are not properly balanced because the tension gets too loose on the bobbin thread....very disappointed to find out it is a known issue with all the viking husqvarna made machines...which are pfaff, janome and viking.....sux.
Oct 21, 2009 | PfaFF Sewing Machines
Viking Lily - free motion quilting - thread loops on underside.
I need more info.
>Where is your presser fooot pressure set(1-9) it should be around 4?
>How fast are you free motioning (faster is better? from 1-10 10 being full speed.
>Is your bobbin threaded correctly (I need to cover the basics.)?
>Never never use a needle smaller than a 90/14 for free motion (I know everyone's an expert...but trust me)
After all this, it's OK to tighten your tension up on top a little when free motioning and getting eyelashes/spider webs on bottom. around 6 should do it though.
Mar 09, 2009 | Husqvarna Viking 1
Free motion quilting Viking Designer 1
I had the same dissatisfaction when I switched from the 1+ to the Designer 1. After some trials I am now happy. You need the springy free motion foot. Part #413 03 76-45. You take off the white shank and screw it on with the metal bar over the needle hook. In the set menu turn the SensorQ on, the free motion on, select stitch 1 from menu V and drop the feed dogs. It also makes a big difference to use the straight stitch throat plate which just has a small hole for the needle to go through. One other hint is that I often have to reduce my needle tension 3 or 4 steps. Hope it works for you.
May 30, 2008 | Husqvarna Viking 1
Sewing Machines Logo
406 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
