Question about Dell 962 Photo All-In-One InkJet Printer
Kyocera printer fs3900DN error code 2200:0076806 how to fix in
How do I change out the fuser fixing unit on a Kyocera FS3900 DN
1. Draw the rear unit.
2. Insert a flat-blade screwdriver to push the
fuser lock (gray colored) on the rear unit and
the fuser unit is separated from the rear unit
(rails).
Do it both ends of the rear unit.
3. Check or replace the fuser unit and refit all
the removed parts.
Place the fuser unit on the rear unit (rails)
and push the fuser lock so that the fuser
lock catches the fuser unit.
Do it for the both ends of the fuser unit.
Aug 08, 2014 | Kyocera Mita FS3900DN Fuser Fixing Unit -...
Kyocera fs3900dn close top cover printer startup sequence halts
Hi
Open the top cover and remove the Cartridge -
With Air Blower - Blow air inside the printer for 2 min
Insert the Cartridge and turn the printer on
Check your Printer now
Regards
Oct 02, 2012 | Kyocera FS-3900DN Laser Printer
Kyocera FS3900DN reporting add paper cass
The problem is with paper pickup rollers.They are at the begining of the tras.
Try to clean it, and try to rotate it.
If it's not moving then try to disassamble it. You will see there is a spring underneath the rollers. Be sure if the spring stands in its place.
Feel free to ask.
Aug 18, 2011 | Kyocera FS-3900DN Laser Printer
Kyocera FS3900DN changed toner and got error 7410:0163053 to call for service
The 7410 indicates a drum error (see below) the 0163053 is the number of prints made by the printer. The drum was most likely knocked loose when installing toner.
Drum unit non- installing error -
The drum unit is not installed or not installed properly.
Detaching and refitting the developer unit Procedure
1. Open the top cover.
2. Open the MP tray.
3. Remove the developer unit.
4. Check or replace the developer unit and refit all the removed parts.
Detaching and refitting the drum unit
1. Remove the developer unit.
2. Open the left side cover and then remove the waste toner box.
3. Unlock the drum unit lock and then remove the drum unit.
4. Check or replace the drum unit and refit all the removed parts.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera FS-3900DN Laser Printer
Error code 0150:0008438
bad engine board... replace it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
May 14, 2009 | Kyocera Mita KYOCERA/MITA - FS-4000DN Mono...
Kyocera FS3900DN Error 7410:0271683
push the drum until it clicks
power off/on
Apr 07, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera FS3900DN Error code Call Service6000:0057457
6000 is the error code 0057457 is the page count
6000 means the fuser is faulty, you're going to have to replace it
Jun 16, 2008 | Kyocera Office Equipment & Supplies
Dell 962 Photo All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
ENFORCER
paulgbrandon
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
