Question about Haier HVT12ABS Compact Wine Cooler
Hvtso6bss stopped cooling - Haier HVT12ABS Compact Wine Cooler
Wine cooler cools but has a very loud, too loud to ignore, whirring sound when it is in cooling mode. Any ideas?
And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
Jan 19, 2016 | Refrigerators
LG Express Cool Turbo GR T542G Stopped cooling
it should run when the comp is on and the unit is calling for cooling, you most likely need a new fan for your unit.
Aug 10, 2013 | Refrigerators
My ac in my dodge truck only works when I am driving, but when I come to a stop it will stop blowing?
Stop blowing cool or stop blowing anr air through the vents??? If it stops blowing cool air, check if the condenser fan is running (it should be)( on drivers side under hood, looks like a small radiator) if not take a water hose and deluge the condenser with water, if it then cools, you will need a new condenser fan assembly.
Aug 30, 2010 | 2005 Dodge Ram 1500
Unit cools for a few minutes then stops cooling. Even fan stops blowing air but the unit remains 'on'
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
May 21, 2010 | Samsung AW1003M Air Conditioner
The compressor stops working. I parked the car for a week and when I came back from out of town it wasn't cooling. I took it to the dealership, they said the relay was popped out o_O. popped it in, started...
sounds like they cant find the problem, i dont think an 03 would have that kind of wiring problem, i think there guessing, could be a bad compressor, but hard to say without checking it . good luck, maybe its time for a 2nd shop to look at it.
Oct 29, 2009 | 2003 Nissan Maxima
Freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Apr 24, 2008 | Hamilton Beach Water Cooler with Storage...
Haier HVT12ABS Compact Wine Cooler Logo
27 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
