Cars & Trucks Logo
Posted on Apr 29, 2009
Ford Falcon AU Futura - ok for 'P' plates ?
1999 Ford Falcon au futura sedan.
Need weight in tonne and power in kilowatts. To ensure allowed under 'P' system, and not classed as high powered vehicle.
Trying to do the correct thing.
Anonymous
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Nov 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
19
Questions
0
Helped
9329
Points
32
AU sedan, wagon and ute is fine for P platers
4beachlife
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on May 25, 2010
4beachlife
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
6686
Points
14
Where do you add automatic transmission fluid in 2000 ford futura au
in a plug on the side of the gearbox under the car (16mm),running in "D" with the engine running at 1000 rpm with the box warm but not hot,pump it in until it runs out of the plug, a pit,hoist or solid ramps will be needed for this as well as 2 people
2helpful
We have a 99 Falcon Futura Au, we need a fuse diagram as it's not on the fuse case & we don't have a manual. We have a light on the dash that comes on when the car is started (fan in box
Probably will not get the fuse info here. I suggest you join up to the Australian Ford Forum. There will be someone there that can help you pinpoint the fuse you want and possibly scan the pages from the owner's manual for you with all the fuse diagrams and email the docs to you.
Here is the web site. Just register on the site and post you question in the correct area.
http://www.fordforums.com.au/
2answers
Hi, i am going to buy a ford falcon au 2001 futura dual fuel which has done 222000 kms, is it a good and reliabel car.
I have the same problem few days ago, and still didn't find any solution. Can any one please help?????20
2helpful
2answers
I need a manual for a 2004 Ford Falcon BA Futura
Please kindly follow the link below to get the manual you requsted for;
http://fitripdf.com/books/ba-gt-ford-falcon-service-manual-2.html
thank you for using fixya
1helpful
2answers
Why does my car stop when I accelerate quickly
oxygen sensor. is it standard air intake? it was a common problem that carried onto the ba's the o2 sensor was failing, have that checked out.
Where is a falcon au starter motor located in car?
you have to be under the car to see it
2answers
Runs perfect on petrol but when changed onto LPG it develops a miss fire on the number 1 cylinder. it is a 99 AU ford futura I hope you can help please
Alittle more info please.What tests/checks have you made ,what parts have you replaced when was vehicle converted and what system was used Factory/aftermarket.
4helpful
1998 au falcon automatic transmission, car wont start in park
check the neutral safety switch, sounds like it needs to be replaced. countrcurt0
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
