Question about Electrolux EWDW6505GS Fully Integrated Dishwasher with 9 Wash Cycles, Nylon Racks, Wave-Touch Contro... 24 in. Built-in Dishwasher
Dishwashers error 11
Posted by Paul Kumbalek on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Hello Paul, thank you for allowing me to assist you!
If you are receiving an error code E11, your dishwasher has detected an issue with the main control board timing out before receiving status of the drain valve. A qualified technician would pinpoint the problem by checking the wiring between both parts. If the wiring isn't the issue, he would need to determine whether the problem rest with the main control and valve. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason.
Best regards!
Posted on Oct 31, 2013
Winterhalter gs502 and getting error 11
Klix-on on motor has failed. (This is often due to overheat) Clear dust and dirt from around motor to restore cooling may be the answer. .
www.cearcommercial.co.uk/.../winterhalter/winterhalter-wps-reminder-er...
May 21, 2014 | Dishwashers
What additional parts may fix error code 11 on electrolux EDW7505HPS0A
Good Afternoon Friend, thank you for your post!
If you are receiving an error code E11 on your Electrolux dishwasher (EDW7505HPS0A), it usually means that you are experiencing a problem with the drain valve. If you have already replaced the vale and pump, at this point, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area that can ensure the wiring between the main control and the drain valve was correctly installed. Best regards! - Z
May 20, 2014 | Electrolux Frigidaire Professional Series...
I cant reset the dish washer is operating in 11 minutes which is rinse only??? I have turned it off, but it doesnt reset. can you please let me know how to reset it?
The reason for the dishwasher to default to Rinse only cycle is likely the heater is faulty. Does this happen with both the drawers?
Also make sure the top panel switches are clean. Use a damp clean cloth and wipe the top panel inside drawer.
By the way Fixya policy does not allow people to respond on direct email addresses. Sorry can't email you directly.
Feb 24, 2013 | Fisher and Paykel DD605SS Stainless Steel...
982 error code miele
I don't have the same model but I found this on the web,
2011-11-25_043923_g600__800_miele_service_manual.pdf
It should point you in the right direction.
Jan 02, 2013 | Miele G892SC SS Dishwasher
Electrolux dishwasher error code 11
You are experiencing a drain valve issue. Main Control Board timedout before receiving status of drain valve. Check wiring between Main ControlBoard and drain valve. If correct, replace drain valve. If error still exist,replace Main Control Board.
Jul 21, 2012 | Electrolux Dishwashers
What does an errorcode 11 mean with a Hotpoint DWF31?
Hi It says for error code 11 ambiant temp too cold , also could be a knik in a hose stopping water
Jul 26, 2011 | Hotpoint Dishwashers
I have a LG Dishwasher model LDF6810 and it has an error code te...thermistor. Can I fix this?
Check the thermistor before you change it it can also be the PCB...
Check the temperature. (Test Mode) If the temperature is displayed, adjust the Inlet Water Temperature to 120 . If the temperature is not displayed, check the wiring connection. check the electric resistance of Thermistor. (11~14k at 77 ) Replace the PCB
Aug 29, 2009 | LG LDF6810ST Stainless Steel Built-in...
I have a LG LDF6810ST dishwasher with a tE error. I've checked the resistance of the thermistor. It reads 17k @ 65 deg , a little higher than the listed range of 11-14. Is this ok? Is the thermistor...
Check the temperature. (Test Mode) If the temperature is displayed, adjust the Inlet Water Temperature to 120 . If the temperature is not displayed, check the wiring connection. check the electric resistance of Thermistor. (11~14k at 77 ) Replace the PCB.
Aug 23, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG Dishwasher LDF7810 SST : tE Error (thermal error?)
Recommend that you closely check the water temp of incoming water. There is an error in some service manuals and if the inlet water temp is greater than 149 degrees (F) (some manuals incorrectly say 194 degrees), you could get an imediate tE error.
If that does not solve the problem:
_recheck_ the electric resistance of Thermistor. (11~14k Ohms at 77 degrees (F) )
Good Luck!
Apr 01, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
Electrolux EWDW6505GS Fully Integrated Dishwasher with 9 Wash Cycles, Nylon Racks, Wave-Touch Contro... 24 in. Built-in Dishwasher Logo
131 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Marvin
Marvin
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
