Question about Bose 901 VI Main / Stereo Speaker
Bose 802 C series II to Yamaha rxv 459 Amp
Well the problem is that i have an bose system controller C but i dnno how to plug it in the amp and how to then plug the speakers to the amp.... So basically to where do i plug the controller to the amp and from where from the amp does it go to the speakers????
Posted by haffibesti on
David Dunn
    Brigadier General:
  • 8,546 Answers
Tech data sheet with diagrams:
http://www.bose.com/pdf/professional/802III_techdata.pdf
In a nutshell, the controller would go between a preamp Stereo OUTput and a dedicated amplifier INPUT. You can't use Bose 901 or 802 EQ in a multichannel setup without separate amps for the Bose speakers.
The Bose 802/901 family uses full-range speakers instead of traditional woofer/tweeter combinations, so they compensate for the response limitations at the extreme frequencies by using severe electronic modification of the program material. Hence, they are a system, functionally inseparable, but the results are outstanding. Consequently, they need a dedicated amplifier so they alone get the processing provided by their electronic component.
In a vanilla stereo configuration you would just put the controller/EQ into a Tape Monitor loop but multichannel sound and digital sources won't work that way.
You should be able to draw off the (assumed) Front L&R channel preamp signal from the MD/CD-R or DVD-R Audio Out (REC) jacks (*). Run that to the Preamp In (or whatever it's labeled on the Bose EQ/Controller). DO NOT run a return RCA pair back to the Receiver as Bose-processed signals will not play well with non-Bose speakers. (*) Run the Output of the Bose EQ/Controller to a powerful separate amp for the Bose 802/901's. I use two channels on a Carver multichannel AV-406 amp but a stand-alone Carver MT-200T also works well. A good clean 100 watts/channel should suffice at home.
* If possible, choose the recorder loop you are NOT using for something else. If you're using the MD/CD-R or DVD-R Audio OUT for a recording device just get some RCA splitters to share the Stereo signal between the Bose and the device at the same time. However, once you select monitoring of that recorder two things will likely happen - 1) you'll lose the Bose and anything digital in the receiver will be disabled.
It's the nature of the digital beast that analog monitoring gets in the way of DSP.
Of course, if anyone who reads this has a receiver with individual analog Audio Outputs for the various 5.1 channels (as I do), the solution would be to draw off the Front L&R channels to the Bose EQ and downstream amplifier and the rest would be the same but without Recorder Loop limitations.
Posted on May 08, 2009
  • David Dunn
    David Dunn Nov 30, 2009
    Did the previous response answer your question?
How to connect my Bose 901 series vI speaker to yamaha rx v740 and rotel rb 1582. Appreciate your help. Thanks
The Bose controller gets wired in series between the pre-amp and the power amp.
I presume you plan to use the 901's as the front L&R pair. So the cables going from the 740's Pre-Out Front L&R go to the inputs on the Bose controller. The outputs of the Bose controller go to the power amp Front L&R channel inputs.
Aug 17, 2014 | Audio Players & Recorders
HOW CAN I CONECT THE BOSE TO MY YAMAHA AMP THE ONLY WAY TO CONECT THE BOSE IS TO BANANA INPUTS ON MY AMP AND THEY ARE FRONT SPEAKERS BUT THE AMP HAS A SUB OUTPUT
To enable the full potential of a SUB for Yamaha DSP A5 ,
you need to have
a separate amplifier for your Bose Acoustimass System.
The SUB out should be connected to an active subwoofer.
Sep 30, 2012 | Bose Acoustimass 3 Series IV - 2.1-channel...
Just purchased the Yamaha RX-V765 receiver. Have
I too have purchased the same receiver and have the same speakers. Did you get a good solution to this problem and how does it sound?
Jul 26, 2010 | Yamaha Audio Players & Recorders
Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
Hi. I would like to connect a Bose controller between a pair of Bose 802 speakers and a Studiomaster Powerhouse 300 MIXER/AMP. The diagram on the top of the controller shows the amplifier connected just...
In a nutshell, the controller would go between any preamp Stereo OUTput and a dedicated amplifier INPUT. You really don't have much choice in the matter. The 802's and their controller are part of an inseperable system.
I don't have any data on your mixer/amp but if you can't insert the conroller logically between the mixer and its amps then you'll have to get separate dedicated amplification for the 802's, with the controller between the mixer and that amp.
May 17, 2009 | Bose Audio Players & Recorders
Question on Bose 3-2-1
hi! you can hook up .. first if your bose amplifier have a phono input you can put it plug and play. but if no pre amp phono input you have to buy or provide (from turntable to pre-amp phono to bose)  to heard and listen to your old vinyl.. mk2 batallion.....
Feb 24, 2009 | Bose 3·2·1 II System
What kind of amplifier and other accessories are recommended for bose 901 speakers
I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
Dec 22, 2008 | Bose 901 VI Main / Stereo Speaker
Hafler power amp has one side out. Would like local repair.Series 9300.Approx.10-15 years old.Not used much.Second time to blow.Runs 4, 8om speakers including 2 bose 802,s (no bose controller or eq in...
just discovered same problem with my Hafler DH-200...right channel out but no obvious problems inside (no loose/burned wires, components, etc). Driven by Hafler pre-amp, but definitely power amp problem.
Sep 03, 2008 | Audio Players & Recorders
Life style error codes 801 & 802
When being in contact with BOSE support i got the message that "FAILED 802 Call Bose" refers to issues with the harddisk not being identified.
In my case I had to send the unit to BOSE support. I replaced the existing disk with an identical unformated one but some more actions are needed. The question is what .......
Nov 18, 2007 | Bose Lifestyle 48 System
Bose 901 VI Main / Stereo Speaker Logo
1,453 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
