Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Fridge Freezer Hotpoint RFA60. Pools of water are collecting under the salad crisper drawers. I have defrosted thoroughly but problem persists
5 Related Answers
Anonymous
SOURCE: hotpoint future RFA60 Fidge Freezer
I have lost the instruction booklet for my Fridge Freezer RFA60. How do I defrost the freezer?
Posted on Nov 08, 2008
projdoc
jasbo
  • 2239 Answers
SOURCE: How do I unblock the moisture outlet?
canned air, wire hanger, anything thick and flexible.
Posted on Nov 10, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: In the last few days
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 13, 2011
oldTech2332
Gene Meier
  • 2341 Answers
SOURCE: I have Hotpoint model CTX18BABKRWW
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
Posted on Aug 15, 2011
imufo2
Leo Ponder
  • 3773 Answers
SOURCE: Hotpoint top freezer and fridge. Water is pooling
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 10, 2011
Why do I get blobs of water on the inside of my salad drawer in my Fridgemaster. Fridge/Freezer
Leaking Refrigerators
I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil on the average of about every 8 hours so the water that accumulates during defrost has to go somewhere right?
APPLIANCE 911
Dec 15, 2015 | Refrigerators
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
Model # ET22DK, water is collecting underneath the crisper drawers.
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 15, 2011 | Whirlpool Refrigerators
Servis fridge freezer freezer fine fridge collecting water under salad drawers and at front, stopper at back is out to try to alleviate the problem. Any suggestions
That sounds like the defrost drain is frozen over. when this happens the defrost water will spill over through the air vents to the ref section. You'll need to remove the evaporator cover in the freezer compartment and defrost the drain. this should get you fixed up. If you can post a comment with the model # and brand of the frig, I'll be able to go into more detailed instructions.
Mar 23, 2011 | Refrigerators
WE have an older fridge. Water is now collecting
Good day,
On some of the older models when the refrigerator went thru it's automatic defrost cycle, the condensate water ran down the back wall, under the crispers and out that drain plug you described.
You can verify if that is your model by looking at the back wall of the machine. If there is no drain tube running down the back, then that is the model you have.
If that is the case, just remove the plug. The water should run directly into the drain pan.
Clean the plug and opening and that's it.
Apr 05, 2010 | Maytag Admiral Top-Freezer Refrigerator
Nov 09, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Water pools under the crisper drawers and looks as if it is draining from the upper freezer down the side of the refrig door, looks like the little hole under the crisper is clogged with rust?? It is a old...
Mine clogs with a soft fungus mat but rust actually sounds better. I run a stiff wire like an unwound hanger into the hole and open it up so the water will drain onto the tray made to collect this water underneath the fridge. Last time I left the wire in place with a long handle and I haven't had water to mess with for many months now. My hole is between the two crisper drawers and when I get into either of them the wire gets a jiggle and I guess that's all it takes to keep the hole clear so the water can drain like it's supposed to.
Otherwise the fungus builds and builds until it sluffs off as a wad and plugs up the works on a regular basis. Too funky for sure.
Jun 21, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Hotpoint RFA 60 Refrigerator drain problem
Well the only way to check it out completely is like you said going from inside your freezer and I like to pour water down the line to make sure it drains.
Take the back panel off inside your freezer and locate the opening of the drain. You will see the collection tray just under your coils and in the middle you will see the opening. Now if it is blocked by ice just take a couple tea spoons of table salt and pour on the opening. Ice will melt very fast and then the opening will clear and then take some water and pour down it.
If the opening is clear just pour water down and observe the drain pan under the unit and see if it comes in there.
Jan 18, 2009 | Hotpoint RFA60 Bottom Freezer Refrigerator
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Hotpoint future RFA60 Fidge Freezer
Nov 04, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
46 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
