RCA P52939 52" Rear Projection Television Logo
Question about RCA P52939 52" Rear Projection Television
Displays POVO 1.22 when i turn tv on - RCA P52939 52" Rear Projection Television
Posted by Kelly Larsen on
APEX LD4088 service menu (advanced menu)
Try this:
  • Turn the TV off.
  • Press and hold the {VOL -} button ON THE TV and
    the {TV/VIDEO} button on the remote for at least 5 seconds.
  • The TV will turn on with the Service Menu displayed.
Here's how to access the SM:
  • While the TV is in standby:
  • Press the {DISPLAY}, {5}, {VOL+} & {POWER} buttons.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
1helpful
2answers
My ti-89 titanium won't graph logarithms (y1=22log(10)x)
The graph of y=22log(10) is a straight line, though it should go through (0,0) and (1,22). Log(10) is a constant 1, so the function is simply y=22x .
If you want "twenty-two times log-base-ten of x", write it as 22*log(x) .
2answers
Apple tv doesn't work when hooked up to denon 2311 receiver. Apple tv is turned on but tv screen displays the word
http://usa.denon.com/documentmaster/us/avr-2311ci_lit527.pdf
This is the link to the probable box in question. The Apple TV needs to be connected to HDMI input port (pick on of the six available). Follow setup instructions.
2helpful
Samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
{DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Proton pltv- 3250 32 "lcd tv a friend gave me
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
2answers
2helpful
2answers
Channel display for Sony WEGA KV32FS100 will not turn off
Most all Sony models use the same programming for the remotes. Borrow a Sony remote and push the display to turn it off.
JVC TV with time displayed and will not turn off.
use your front control button to try to enter yoyr menu settings and if possible turn off display function.
1helpful
Wega sony KV-36FS17
if you use your Sat remote control turn your tv on/off and there is an info button on the remote. press the tv button and then press the info button that should to it.
Open Questions:
See all RCA P52939 52" Rear Projection Television Questions
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
