HP 12c Calculator Logo
Posted on Apr 28, 2009
Screen is flashing 0.00
I replaced the batteries on my HP-12C and the screen is flashing 0.00 and the calculator will not turn off. Please help. THANKS!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
745
Points
I had the same problem with my HP 11C. The following solution worked for me.
1. Remove the battery cover.
2. With the batteries in place (i.e. DO NO REMOVE THEM), use a small piece of wire (I used a standard staple bent at one end), short the terminals FOR A BRIEF MOMENT between both ends of the set of batteries (the HP-11C has three). This means somehow inserting the staple such that the contacts in the batteries receptacle are shorted.
3. The flashing will stop. Then push the ON button until the calculator turns on. If it does not work the first time, remove the batteries and resinsert them.
4. You may have to repeat this procedure. I had to do it twice before my calculator worked again.
  • Anonymous Sep 13, 2009
    In addition to the solution I posted, when you remove the batteries (with the calculator being turned off), be careful not to push any button while the batteries are out. This has the effect of resetting the continuous memory, and the calculator may not respond to any keystokes afterwards.
How do get the comma out. It has 0,00 and I want 0.00
1. On the HP 12C the default separator is a comma.
2. Turn the calculator off first by pressing [ON].
3. Press and hold [.] (that is, the decimal point key) and then press and release [ON] to change the digit separator from a comma to a point.
4. Perform the same steps again to change the point to a comma.
My HP 12c is showing 0,00 on the display...if I add 2 plus 2 it shows 4,00. Not sure how to reset? It also has a blinking * which I understand is a low battery indicator...are these two things relat
No, they're not related.
To switch the radix mark, turn the calculator off, press and hold the decimal point key, press the ON key, then release both keys.
1helpful
Flashing asterick in lower left of screen; ever since will not correctly calculate PV or PMT
I believe there are two separate issues here.
The asterisk in the lower left corner of the screen is the low-battery indicator. Put in a fresh set of batteries and that will go away.
As for not getting the correct results, are you sure you have all the modes set correctly? Could you post a sample problem, with the results you get and the results you expect to get?
9helpful
My 12c has a flashing asterisk in the left hand corner. how do I turn it off?
That's the low battery indicator. To turn it off, replace the batteries with a new set.
7helpful
The display on my HP12C shows 0,00 instead of 0.00. Can you help me fix it? Thank you! Rebecca Loughlin [email protected]
To switch the radix point between the US and European modes, press and hold the decimal point key, press and release the ON key, then release the decimal point key.
1helpful
When the calculator is turned on, the display reads 0,00 and then in the below right side there is a letter C. How do I clear this?
If the C indicator is displayed it reminds you that interests are compound interests. It it does not show, interests calculated are simple.
To toggle between compound and simple interests, press the key sequence [STO][EEX].
HP 15c Passes self test but screen flashes - wont turn off
You can get rid of the flashing (usually due to memory overflow) by pressing [<-- left arrow] [ON] or [g] [CF] 9.
If you want to reset permanent memory
1.Press and hold [ON] then press [-]
2. release the [ON] key, then the [-] key.
Screen displays Pr Error.
Press any key to clear display.
Hope it helps.
2helpful
2answers
Min eis an HP 11C. flashing 0.00
If the asterisk is flashing, the batteries you put in are not good either.
7helpful
Display Problem & Question
To remove the comma, turn off the calculator. With it turned off, push and hold down the [ON] key. While still depressing the [ON] key, push and hold down the decimal or [.] key. Now you should have them both held down. Now, release ONLY the [ON] key.
To remove the "c", push then release the [STO] key. Then push and release the [EEX] key.
k24674
Grand Canyon Tech
Grand Canyon Tech
