Sharp AR-407 Copier Logo
Posted on Apr 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp ar 407
I hav ea sharp AR 407 copy machine. The error code is E7-00 Is there a code to fix this?
Everett Lin
Level 3:
President:
  • Sharp Master 990 Answers
  • Posted on Apr 28, 2009
Everett Lin
Sharp Master
Level 3:
President:
Answers
990
Questions
Helped
434140
Points
3069
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
1helpful
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
1helpful
How to fix Sharp Ar-407 Code F2
There are a lot of choices for F2-?? Hold down the Start button to see the remaining digits.
Sim 22-6 will print all jam codes & error codes. It should be a process control code. F2-31 or F2-37, Drum mark or image density. You can execute 44-6. This should show which is out of range. Pull the drum unit out & clean both sensors. Check that the blade is cleaning from end to end that the DM is visible to the sensor.
8helpful
2answers
SHARP-235, F5-02 CALL FOR SERVICE CODE
Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service u9-99 what dos it mean and how can i
1helpful
Error code H4 appear on display when voltage low in photo copier machine sharp AR-a61
in order press P * C * or # * C *. the machine will go into diagnostics. Then enter the number 14 as if making 14 copies. Then enter 1 and press start. That should reset your machine.
PLEASE let me know if this fixes it.
8helpful
4answers
8helpful
Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Sharp AR-5132 blank copy
see comments, loose blade by roller, push in, fixed
67helpful
13answers
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
