When oven timer comes to zero then the heater goes off. At this time light may remain there or goes off depending upon the model. Sometimes it is linked to opening and closing of door and actuating a micro switch. So first thing is to check this micro switch.
There are a couple of microwave ovens out there where after it has finished cooking, the light and fan continue to run until you open the door. Then the fans shuts off, but the light remains on. When you close the door, then the light shuts off. If the light and fan go back on when you close the door, then you have a bad door switch.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
Program the oven to self-clean.
Wait 20 seconds.
Cancel self-clean.
Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
Remove the oven racks.
Set your oven control to "Clean."
Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock
Thanks for using fixya.
try turning off the circuit breaker, resetting the power sometimes trips the self clean latch to operate, youll need to push in the door light switch.(it will have to think the door is closed to operate)
