The BJ200 is quite an old printer. The problem you're describing is indicative of a head failure. If replacing the cartridge doesn't work, you may have a faulty head. If the cartridge includes the print-head (some do) it could be the contact strip on the cartridge cradle.
My honest advice would be to retire this printer, and buy a new one. Even the most basic model you can buy now would exceed the bj200ex in both quality and speed - and would be inexpensive to buy.
SOURCE: canon bubble jet 5500 printer install software
All Your Software Is Located Here
Thanks For Using Fixya.com
Sincerely,
Michael Scott
SOURCE: Canon BJ-30 Bubble jet printer F-12 error
Hi, According to my BJ-30 & BJC-70 user manual, if F12 is blinking, it is required for this Error code to get in touch with a Canon Service Centre. I had this in the past and being curious I removed the printer chassis from case the and found the problem to be a loose ribbon cable in the connector on the main board from the touch pad circut board . I also had the identical problem with my BJC-70. These printers are very reliable and compact, it seems to be a problem which I think comes about from these printers being so portable. It took me about 15 minutes to fix the problem for which I have made a small modification to hold the cable in place. Having said this, it may not necessarly be your problem but it is a starting point. Canon to my mind have not made another portable printer this good, so if you value it and can find a trustworthy technician get it fixed. If you want further info contact me here.
Regards Roger D
SOURCE: I can't find ink cartridges for it anywhere.
Take a look at my tip on cartridges it may save you a lot of time and money
http://www.fixya.com/support/r3845491-ink_cartridge
OR
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Hope this gives you the information you need
Bob
EXMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
SOURCE: My canon BJ 10 EX bubble jet printer wont
Yes you are right there is an electronic detection of the paper detection at the insert point. This is an optocoupler which can be checked for the failure of the detection. replace and proceed. Good day
Testimonial: "Thank you that's great. Regards PB"
