How do I scan multiple pages to PDF on a HP LaserJet M4345 Multifunction Printer and how do I retrieve the document once scanned as there is no usb port nor any other visible means of getting the file?
I'm assuming that you're trying to scan to your computer.?? I'm not specifically knowledgeable about the HP M4345 printer.... but, it HAS to have a cable connection. The cable should be one that has a usb connection on one end, and a small kind of rectangular plug on the other that plugs into the back of the printer.. Look on the back of the printer. There has to be a connection, besides the jack for the 110 V.
SOURCE: 1) whether the scanned document from this
The answer is yes to both questions. Follow the instructions below:-
Go to Adobe Acrobat. Click on FILE. Click on CREATE PDF. Click on FROM SCANNER. Click on SCAN. You should now be scanning your first page, after completing it you will be asked if you want to scan any more pages or close. Select to scan more pages till finished. You can also select to have Acrobat do an OCR after the scan which will allow you to search the document. To do this, click on DOCUMENT, click on RECOGNISE TEXT USING OCR and click on START
I also do not have Adobe Acrobat, which could be a further complication
