I have 2 problems with my lg hb 966trw: a) cinavia.. it is active and sound goes off in almost all dvd/blu ray after 20 minutes. a) region code. Initially I could not play any DVD/blu ray. then following some recommendations in forums I changed area to GB and managed to watch.. but then again together with the cinavia problem I cannot open almost any DVD/bluray so it seems my problem is a combination of area code and cinavia.
For the issues of region code and Cinavia audio mute which is Cinavia code 3 issue, you can check these 2 tutorials:
How to Fix Cinavia Message Code 3
How to Remove Blu-ray Disc Region Code
Follow this steps and fix it. God bless you
No power
Screen is "frozen" or completely black, or
Power button does not work
(DVD player's power supply transformer could be burned out)
Does not play disc
No sound
switching regions:
Turn
on your DVD player.
Open
the DVD player's main drive, also commonly called the DVD "tray." The
region cannot be changed while a DVD is in the machine, so many DVD players
require the tray to be open as an extra precaution.
Push
"Info" or "Setup" on your remote.
Use
the remote to select the "Region" option as indicated on your TV
screen.
Select "Region 9" to change the system to
multiregion formatting. Regions 1 through 8 represent specific geographic
locations and will not allow multiregion playback.
SOURCE: I have a blu-ray home theatre system that wont
Go to this site http://www.megaupload.com/?d=4H157815, download the file, load it to a CD & play it in your DVD
It is very simple to use.
1. Download data
2. Unzip it (password
needed)
3. Burn them on blank CD (or DVD)
4. Insert the disc to your
player.
5. Start updating.
Now your player can play any region DVD disc
SOURCE: I bought a DVD movie from France (region code 2)
Do the following using the remote of your player
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Count ten and Power up the player.
Ir will not work for Bluray disc, only for DVD's. Blu Ray region unlocking would require hard ware modification.
The time has come to consider a new player, the repairs will exceed the value of a new one.
