Question about ESA ET432E TV
I need a dish network remote control code for an ESA television.
I need a Dish Network remote code for an ESA TV.
    New Friend:
Try some of the akai tv codes in dish network directory, firstone worked for me, hope it works for you
chris
Posted on Feb 13, 2010
How do I find the remote code for my dynex TV?
Remote Control Codes For Dynex TVs ' Codes For Universal Remotes
codesforuniversalremotes.com/remote-control-codes-for-dynex-tvs/
  1. Cached
  2. Similar
5 digit remote codes for Dynex TV = 10463 11463, 11780, 11785 ... with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc... Do you ...
RCA : Remote Code Finder : RCRN03BR : TV
www.rcaaudiovideo.com > Remote Code Finder
  1. Cached
  2. Similar
Durabrand, 10463, 10178, 10171, 11034. Dynex, 11463, 11785, 11810, 12049, 12184. ESA, 10171, 11944, 11963. Electroband, 10000. Electrograph, 11755.
Dynex TV Remote Control Codes
https://www.dynexproducts.com/remote-control-code
  1. Cached
Here is a listing of the most common Dynex TV codes for universal remote ... PHDVD5: 115; Phillips PMDVR8: 115; RCA RCU807: 135; Rogers DCT3250: 0463 ...
Universal RCA remote code needed for DYNEX tv [Solved] - Fixya
www.fixya.com/support/t8402745-universal_rca_remote_code_needed
  1. Cached
  2. Similar
Feb 22, 2011 - Hello Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv. Codes are 11463, 11810, 12184. code for my dynex Google Search
Dec 22, 2016 | Dynex Televison & Video
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Remote code for dish network for esa 42" plasma tv
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. In order to program your remote to your TV you will need to first locate the model number of the remote. The model number of the remote will be located on the back of the remote at the top, usually a two to three digit number with a decimal point. I will list here for you the best remote codes for our more popular models of remotes. I hope you find this information useful and if you have any further questions or concerns feel free to email directly at [email protected]
Remote Model Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 569, 632, 505, 516, 669, 636, 627.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 632, 667, 666, 233, 846, 733.
4.0 and 4.4 IR/UHF remotes - codes 733, 632, 569, 516, 537, 627.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 632, 569, 738, 537, 764, 733.
20.0 IR and 21.0 IR/UHF remotes - codes 672, 632, 654, 516, 777, 846, 738.
Instructions for addressing remote to TV
  1. Turn the Television On.
  2. Press and hold the TV mode button until all the mode lights light up.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Sep 15, 2011 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I HAVE A ESA FLAT SCREEN TV AND I NEED THE MOST CURRENT CODES SO I CAN PROGRAM MY DISH NETWORK REMOTE , CAN YOU HELP ME PLEASE TV MODEL # IS PDP4294LV1
We currently have no codes listed for this brand try the steps below this is a process called a Power Scan it should resolve this for you.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
May 30, 2011 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Need tv code to reprogram a dish remote
Have you tired to cycle through the codes stored in the remote (read link here)? Here's a link for the remotes codes for specific TV's (click here). It appears the only code for ESA is 733.
Here is a link on how to enter the code (click here). Hope this helps.
Jan 31, 2011 | ESA ET427E 27" TV
Remote control code for dish network for Emerson LC320EMX 32'' tv
Your Dish remote was probably designed years before the Emerson set and may never have codes for it.
However, you can try the followng brands from the Dish code list to see if you can get some basic functionality:
Funai, Symphonic, Sylvania, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, Philips and Misakai
All of the above are manufactured by Funai - the least and lowest of the Japanese electronics firms.
Sep 07, 2009 | Emerson Televison & Video
Cant program dish network remote to my sylvania tv/dvd combo
Not likely will your current remote ever have the capability for your newer model. The code sets are designed into the Dish remote as they were available then and don't 'learn' newer sets.
You might try to find one of the other Funai brand code sets under these names:
Funai, Symphonic, Emerson, Aventura, Durabrand, ESA, Magnavox, INSIGNIA, and Misakai
Even if you do find one that gives you some functions, I doubt you will find one set for both TV and DVD player so you will have to try individual code sets; one for TV, another for DVD.
Jul 12, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Need sharp tv codes
The codes for a Sharp are 526, 585, 591, 605, 606, 607, 608, 628, 629. Thanks for using Fix Ya.
Jun 02, 2009 | DISH Network IR Remote Control
Need code for 32in.olivia tv
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127
Satellite TV Systems Dish Network Remote Codes 506 or 127
May 23, 2009 | Syntax Olevia 537H Television
Remote control code for ESA ET427E 27" television
0053 worked for me on this exact model.
Oct 11, 2008 | ESA ET427E 27" TV
ESA ET432E TV Logo
1,011 people viewed this question
Top ESA Televison & Video Experts
Ekse
Demonic-2011
Demonic-2011
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
