Question about LG 42PX5D 42 in. Plasma HDTV
LG Plasma has sound but no picture
I have a 42in LG plasma tv, it has sound and no picture. What could be the problem? Give me an estimated cost of repair.
Thanks james
Posted by sing56 on
  • Anonymous May 08, 2009
    I have the same problem my LG plasma 42". I just called LG cust. service and they said that I am 6 months out of warranty, but that they will cover parts. I need to fax them a copy of the purchase receipt, they will then provide me with the contact info for repair. Good luck, HTH.
  • Anonymous May 16, 2009
    no picture ,has sound
Anonymous
    Problem Solver:
  • 13 Answers
Hi James,
This could be one of two problems. I can't narrow it down any further without having the set in front of me.
1. The plasma panel or the componets which supply electricity to the plasma in the panel have packed up.
2. The video processing unit in the set has gone.
As for the cost of repair, if it's the panel, buy a new TV. It'll be cheaper. If it's the component that supplies the electricity to the plasma on the panel or the video processing unit, expect to pay between 300-400 as a conservative estimate for parts. Labour would be another 100-200.
Hope this helps
Posted on Apr 28, 2009
Anonymous
The culprit will usually be the lower y-sus video board which is a common problem with lg plasma sets.
easiest way of finding out is to get a competent person to remove the back panel-remove the board and power the set up-if it is this board the set will display the top half of the picture only-when replaced no picture will be displayed.
these boards can be obtained on e-bay for between 60 and 90 pounds and take minutes to fit.
estimated cost of a proffesional repair £400-600.
Posted on May 11, 2009
I got LG 42LE4300-DA it wont turn on , but i can see the red light in the bottom of the tv when i try to turn it on, but there is no picture or sound either ·
Sorry I never try guessing . most repair shops will give you an estimate of repair costs .perhaps not free but usually if you get it fixed there then they do not charge for the estimate .
Sep 30, 2015 | LG Televison & Video
LG 42PC!R Plasma TV turns on and then green led blinking with no ppicture and sound !
Your problem is most likely a fried circuit board. I always connect my good electronic to a back up battery. but your problem might have been storm or surge related, I would take it to a repair center and get an estimate.
Sep 19, 2014 | LG 42PC1R 42 in. Plasma HDTV
Have a plasma samsung hpt5054 i have sound no picture is it worth fixing thanks
On a plasma that usually means a problem in the power sections. You should be able to get an estimate from a repair shop or Samsung repair depot. On that size of tv it should be cheaper to repair than replace unless it is several years old. Usually on a smaller tv just out of warrenty the cost to repair is worth more than just going out and buying a new tv.
As long as you know your replacement cost and get an estimate you will come out on top.
Jun 14, 2010 | Samsung HPT5054 50 in. HD-Ready Plasma...
Picture takes split second to focus
That normal,this tv a year or more right?Mornal progressing the aging of the tv.
Mar 19, 2010 | LG 42PQ30 42 in. Plasma TV
Cracked on Inside glass on 42in Plasma-Panasonic
This sounds like the panel itself is cracked. If this is the case, the set wil not completely power up as youi have seen. The panel can not be repaired as such, it must be replaced. I can rpovide you with the part number and cost if you can post the model number. Be aware however, that the cost of the panel may come close to the cost of a replacement set.
Dan
Dec 10, 2009 | Panasonic Televison & Video
Hi , i have an LG 50px4D plasma TV problem is i have no picture , however sound is still working , is this a common problem ? can i repair myself ? thanks Mark
You could replace the boards yourself, however it will probably cost in the area of $500.00 to do it regardless if you or a service company repairs it.
Dec 09, 2009 | LG 50PX4DR 50 in. Plasma TV
Turn my LG 42PC3DC-UE 42in. and all it do is click on and off what can i do about that
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common problem are the power supply for the screen itself. Most manufactures call it a Blacklight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
No picture
Sounds like the video card went out. It's a technical thing and only tv repairman can repair. Some give free estimates and some repairmen waive the estimate if you allow the repair. Good luck.
Jul 05, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
50 inch LG plasma model 50PX5D. Lost picture and sound
well it looks to me u need a new tv....all the details u give are pointing that ur picture tube is gone.....but call LG help and costumer line and ask them......u may get away from it to get a new tv
make sure when u get a new plasma to extend ur warren tie to a max o 3 to 5 years and if this would happend u get it repaires for free.......cost for a new screen app 1000 to 1500 dollars
Mar 12, 2009 | LG 42PC3D 42 in. Plasma Television
Does this make sense?
Hey graceylou,
Unfortunately, the estimate provided by the repair technician may be correct. While screens can generally be replaced, they often prove to be one the most expensive components of any LCD or plasma TV.
If you are in doubt of the prices quoted to you however, I would strongly suggest contacting LG directly for more information. Many manufacturers are able to provide ballpark figures for replacement parts, especially those that are the most prone to damage or susceptible to hardware failure. Remember that labor charges may not be included in any estimate provided to you by LG, so you may wish to confirm with your repair tech if these charges were included in the $1,200.00 you were initially quoted.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 24, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
2,496 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
