Video Game Consoles & Games Logo
Posted on Apr 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dtv converter box, no PS2
I hooked up a dtv converter box, now ps2 won't work. I have an older rca tv (circa 1993). Previously had an RF modulator hooked up, and I tried hooking it in to the magnavox converter box, but still no picture from the PS2. Help, I need my games.
Juan Rivera
Level 2:
Novelist:
  • Expert 172 Answers
  • Posted on Apr 29, 2009
Juan Rivera
Expert
Level 2:
Novelist:
Answers
172
Questions
0
Helped
82823
Points
465
You need to hook up the ps2 directly to the tv not the converter box the converter box is only for digital Chanel's that will go off air on june 12 but if you have cable or satellite then you don't need a converter box this is only for free Chanel's with they don't requires subscription to cable or satellite your playstation should work with out the box try to hook it up directly to the tv not the box
How to hook up ps2 to a emerson tv
Hi Bonnie, first, we need to know if your TV is compatible for the connections from the Playstation. The way to tell, is do you have the matching RCA inputs on the TV? These are the Yellow(Y) Red(R) and White(W) cords that come with all PS1's 2's and 3's. (Yes, all years and models are exactly the same) If your TV does NOT have the matching RCA inputs, don't worry! You can still hook it up to the TV, but it will require another piece of equipment. You will need to add a signal converter box(I will put in a link for it) What this does, is lets you plug the cords from the Playstation, into the box, then out too the place where you plug your cable or TV antenna. These boxes are also called RF Modulators. They are available at every local Walmart or Meijers respectively.I hope this helps. Good luck. ^^
RF Modulator TV Switch Audio Video RCA Ant Input to Type Coax Output...
tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
How do I hook my old PS2 to my RCA TV with my converter box?
RF cable coax out to TV from the RF Modulator .....RCA jacks "red-yellow-white from ps2 to RF modulator "its not called a converter box"//lol Put the TV on channel 3 you should see the ps2 screen. Same way you would hook up a DVD player to a CRT TV..heres a video
TVs DVD Players How to Connect TV DVD Player VCR With Modulator
2answers
I conected the converter box and then took it off it erased my ch
You will have to get a RF Modulator so that you can hook up converter box and your ps2, your tv is saying progam channels because there is no box hooked up anymore,
Hope this helps.
PS2 won't work with magnavox dtv converter box
first off make sure u have the box turn off
this is what i would do:
i would get a short coaxile cable and splitter and hook them up to your tv
........................TV.........................Coax input
.........................|..............................Coax Wire
......................../\.......................................Coax Splitter
....................../...\.......................................Coax wire from ps2 and dtv box
...............PS2......DTV box......................
Hope this helps
I have a Sanyo TV from approximately 2001-2002. And I'm trying to connect rca cables so that I can hook up my old PS2 with an input box [I think it's called.] but there's no rca connections in the back....
Ok if you want to hook up RCA cables to that TV and dont have a adapter you can buy a RF MODULATOR ( Wall-mart / radio shack for $20.00) and use that to conect to TV and the ps2 will connect to that ( this will also let you use a DVD player with the TV!)
Instructions in RF package!
PLEASE RATE THIS RESPONSE AND HELP KEEP THIS SITE FREE!
THANK YOU!
DTV hookup for an RCA XL-100 TV
Buy a box modulator which have RF input then have RCA output that's input to your TV or other option below.
Just click and choose whatever hooked up connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
HP TVs - TV Cable and Connection Types
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
2helpful
Need to install a PS2 to a cable box.
unhook the cable box from the tv and hook that cable into the ant in on the modulator and run the output of the modulator to the tv.set the modulator and tv on channel 3.you may have to turn off the cable box to play ps2.please give me a rating if this was helpful,if you need more help just ask
2answers
PS2
just connect the yellow, red, and white cables in the front or back of the t.v and then tune to channel 3
Rear Projection and PlayStation 2
Hi, If your PS2 has an RF module, it is possible that the PlayStation 2's RF unit is interfering with your reception. Even if you are using the Audio/Video OUTput of the PS2, the RF module is also working and throwing out an output to either Chs 3 or 4. By switching off the PS2, the RF module would likewise be off. If by switching off the PS2 does not solve the problem, it is also possible that the Video input board of your TV has been slightly damaged. I doubt if it is a major repair and offhand would probably involved minor components or simply re-soldering. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
