Question about Lexmark X4650 InkJet Printer
Lexmark X4650 ink jet printer has paper jam
There is no paper stuck inside the printer, yet it still displays 'paper jam' on the screen. How do I correct this?
Posted by brophmich on
Sanath Kumar V
  • Lexmark Master
  • 684 Answers
Please follow these steps to set your printer to defaults:
1. Please make sure your printer is set in Copy Mode.
2. Press the "setup" button, you will find "Maintenance" displayed.
3. Use your arrow keys to locate "Set Defaults" and press "OK".
4. Press the arrow key to find "Use Factory" and press "OK"
This process would reset your printer to Factory defaults.
Posted on Apr 29, 2009
Hi, Sirs; My name is Heiman, Today I have one question want to request you that, I can not push to stop the button of paper jam in appear a flashing error on the printer. And also when I want to print...
Paper jam means a paper has got stuck up on your printer. open the printer and see if you can carefully pull the paper that has got stuck up in the printer out. after that try fixing the papers correctly in it right positions. or don't load much papers again. if you know you want to print only a page of work, then try putting on one paper inside.
I hope this works for you.
May 16, 2011 | Lexmark X2600 InkJet Printer
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Dell 922 saying there is a paper jam
    First try this. Turn off the printer, remove all the cartridges, drum, open all the doors and remove all the trays. Now verify that there's no actual paper jam by exploring through the inside of the printer. You can use a blower to blow any dust or pieces of paper, etc.. from the printer. Now use the manual feed and put in thicker paper several times (push in and pull out). Again reinstall and reconnect every components and boot the printer. If the actual printer's paper sensor isn't broken or stuck or twisted, this will definitely clear the paper jam message on the printer.
    If the problem persists, please download this small text file and follow the instructions (click here). Open the link, click "Download Now" button, wait for 20 seconds and again click "Download File Now" link and read the instructions and follow step by step.
    Good luck.
    Thanks for using FixYa.
    Jul 16, 2010 | Dell 922 All-In-One InkJet Printer
    I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
    If paper is jammed, a Paper jam message will appear on the control panel display.
    Follow these steps to clear the jam:
    1. Gently pull any jammed paper out of the output tray or sheet feeder.
    2. If the paper is stuck inside, turn off the Epson Stylus CX.
    3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
      alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
    If paper jams inside the Automatic Document Feeder, clear the jam as follows:
    1. Open the Automatic Document Feeder cover and remove any jammed paper.
    2. If necessary, lift the document cover and remove any paper that has jammed inside.
    3. Press OK to clear any messages on the display screen.
    Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    Stylus CX9400 Photo Printer: paper jammed inside printer...
    May 18, 2010 | Epson Stylus CX9400 Photo Printer
    Paper jam
    The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
    Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
    1. Turn off your printer
    2. Open all trays and remove any paper stuck there
    3. Locate the button to open the printer, open it and remove any paper stuck there also.
    4. Repeate the above step for all buttons that you can find to access the inside of the printer
    5. Close all doors and put back all trays
    6. Turn on your printer
    NOTE: Please rate our help to keep this free service online.
    Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
    My ip100 printer keeps displaying paper jam when there is no paper in the printer
    Dec 10, 2009 | Canon iP100 Portable Printer
    Canon imageclass mf6530 paper jam error wont go away
    check where that u removed the paper and see if one of the sensors is stuck or out of place. also look for a piece of paper. you may have to get a flash light to see better
    Aug 05, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
    Message reads: the paper is jammed clear the paper and press OK
    Even if a small piece of paper stuck inside the printer you ll get this msg.  So what you have to do is if you have a Air blower or vaccum cleaner blow air inside the printer,  If any piece of paper is stuck inside it will come out and you won't get that msg again.  Try this and sure it will work...!
    Mar 18, 2009 | Office Equipment & Supplies
    Lexmark X4650 InkJet Printer Logo
    847 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Ekse
    Muntejaya Ginting
    Muntejaya Ginting
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
