Since when you are facing this problem, did you make any recent hardware or software changes ?
And after you turn on your laptop, don't you see anything after that cursor(Underscore) blinking ?
I mean it boots to windows or not ?
If not try to remove your battery and keep it aside for 5 Mins. and then connect it again. Then try to turn on the laptop
Testimonial: "It doesn't boot to windows. It doesn't boot anything. What I've read from similiar problems is they get the black screen after the logo comes up, so they can hit F keys to get to safe mode or boot manager, I can't. The very second it turns it, it immediately goes to the black screen with non blinking white underscore. No logo, no start up, nothing. Turn on, right to black screen. After looking for a similiar problem like mine for a month, I've given up, and turned to asking for help."
SOURCE: Dell latitue D610 stuck on black screen with a blinking cursore.. help?
First, try and boot into safe mode by powering off your computer then powering it back on and tapping the f8 key, after that you should see safe mode and other options below it, click the first option which is safe mode, then go into your start menu and go to your system restore which in Windows 7 and Vista is located in accessories and then system tools, then choose a restore point earlier than the date you are on. This is a temporary fix and you will need to get a virus removal done asap. Hope this helps.
Live Technical Support
My Youtube Channel
SOURCE: i have a compaq mini
connect external drive & now set booting order from bios select first booting device as usb drive
,save the settings
put bootable disk in drive, boot from it
reinstall your OPERATING SYSTEM.
SOURCE: Black screen and flashing white underscore.
Hi .
when you go into your setup ,go to disply and see if anything has changed?
let me know ...................good luck Roy
