Question about JVC Video Cameras
Shows fault E04 remove & reattach battery
JVC Camcorder gr-DVL9700, approx 7 years old, when switched on after a few seconds shows FAULT 04 REMOVE AND REATTACH BATTERY. UNIT IN SAFEGUARD MODE. Manual says remove battery 3 times if not rectified contact dealer. The battery is fully charged, I have also tried without the battery connected to the mains via the charger, still says same. JVC gr-dvl9700. Same problem. When i switch on unit says "error 04. unit in safeguard mode. remove and attach battery. Juts happened today for the first time.Any suggestions please?
Posted by miffer7 on
Anonymous
    New Friend:
  • 4 Answers
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Posted on Dec 17, 2009
  • 5 more comments
  • fuzzmaker2 Dec 21, 2010
    I read somewhere on one of these chats date mid 2009 that if you tap the bottom of the camera it will fix the problem. I tried it and it worked perfectly.
  • wolfmagic4 Dec 25, 2010
    I tried this fix and it worked great! Thanks for the input.
  • pops_880 Dec 28, 2010
    HOLY Sh-----t It worked, I taped on the bottom of the camera and it worked :P I cant beleave it LOLha ha hah ah h thank you for your advice hope it worked for the other feller thanks.
  • liliesinpari Feb 16, 2011
    I don't know how or why but the tapping worked! thank you
  • pianogirl813 Feb 19, 2011
    Tapping the bottom worked! I did it with a fully charged battery and tapped it pretty hard all along the bottom with my finger tips and it worked after 4 tries. Thank you fuzzmaker2!
  • fixya320 Feb 26, 2011
    this is no joke. i just did the very same. i rasped it pretty hard about 8 times on the underside with the handle of a metal kitchen knife (after all what had i got to lose). voila! camera now works! obviously something inside is getting stuck and this frees it. it got this e04 when it had been idle a long time so clearly something gets jammed when the cam is not in use for a long time. that camera was out of action for a few years but just gave it to kids as photo was working. i thought i'll try one more time to fix it. sorted! this is not the only device i have fixed with a good hard knock. weird huh!
Simon Wright
I tried turning it on to play while pressing the rewind button and it worked. This may have been a coincidence, but I'd love to know if it works for anybody else.
Posted on Jun 29, 2013
When i switch on my JVC GRDVX9 it says on the screen E04 unit in safe guard mode remove and reattach battery
Following are the solutions:<br /> 1. Through your camera in dustbin;<br /> 2. crush it with hammer <br /> 3. Put it on fire
Nov 09, 2009 | JVC GR-DVX9 Mini DV Digital Camcorder
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
Mar 30, 2009 | JVC Video Cameras
E04 Error
Eject tape leaving cover open and remove battery. Re-insert battery and re-insert tape also leaving cover open. Keep repeating this process until eo4 message disappears. This worked for my GR-DVL100e after about four repeats. After getting your camcorder operational, they say it is good practice not to leave tape in camcorder when not in use.
Jun 26, 2008 | JVC GR-DVF21 Mini DV Digital Camcorder
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
JVC GR-AXM18U Compact VHS Camcorder
perhaps you should turn off the camcorder, remove the battery, wait a minute, and then put it back in.
Jan 11, 2008 | Video Cameras
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
E04 Error Message
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. Good Luck, i'm off to buy a tape head cleaning cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Oct 17, 2007 | JVC GR-DVF21 Mini DV Digital Camcorder
Video Cameras Logo
1,299 people viewed this question
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
