SOURCE: Jam in the document feeder
I think I found my answer. You don't have to un do any screws. Lift up the cover to the automatic feeder. You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it. Then you will be able to see the jammed paper, which which I was able to carefully pull out with a pair of tweezers. Some was under rubber rollers, but when I pulled the paper sideways it slipped out. Now it works!
SOURCE: Brother MFC 8840, Document Feeder is not workting
ITS PROBABLE THAT A CONNECTOR CAME OUT.REMOVE BACK CORNER PANEL AT FEEDER CABLE TO CONFIRM.
SOURCE: Brother MFC 8440 Scanner has a line
Whoaaaaaaaaaaa!!!!!!!!!!!!!!!!!!!!!!!!!! No need to da all that. Lift up the Doc feeder and look at the SMALL strip of glass, you will see a dot or something on it, clean w/alcohol. Voila taken care of. the dot ( pen mark, white out, etc...) makes a line because the document is Moving and that dot now looks like a line to the copier. :)
SOURCE: BROTHER MFC 7420 PRINTER SOLID VERTICAL LINE...
Open te lid and look at the glass. You have dirt or white-out or something on the thin strip of glass to the left. Clean that glass!
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
