Taylor & Digital Scale Lithium Scale  Logo
Posted on Apr 28, 2009
I have a Taylor 7542 . In dragging it from its box one of its little round feet came off and now it obviously cant give a corect weight assessment. Where can I find a new set of feet? Bob M.
reici_42
Level 1:
  • Contributor 3 Answers
  • Posted on Oct 10, 2010
reici_42
Contributor
Level 1:
Answers
Questions
Helped
1575
Points
11
  • reici_42 Oct 14, 2010
    Contacted Taylor and they are not very customer friendly. They do not sell replacement parts and unless it is under warrenty you are out of luck.
How do I get a manual for Taylor 7542 Lithium Electronic Scale?
Try this link to the manual: http://www.taylorusa.com/media/IBs/7542_ib.pdf
Thottle body for 7542 right side hits throttle body??7542 taylor
what car,?
what engine.?
what problem. ?
if savvy , tell country too, or all hawsers will be wrong.
if something hits, we'd need a photo , of that. we tad blind here.
1helpful
Gives me diffrent weights even though I am weighing myself within seconds of time, and in the same spot on the floor.
I've found I have to weigh myself, step off, weigh myself with something in my something heavy in my hands, then weigh myself again. The 3rd weight you get will be your correct weight. If you needed the manual, I have uploaded in into photobucket...although it doesn't really address this issue.
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
21helpful
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
2answers
My Scale stoped weighing me, now it reads 1-ld .
The sensor has been worn out or has been pushed past it's weight limit. When you get on it, it pushed the sensor past the point of working... When she gets on it, no problemo...
29helpful
2answers
We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
I replaced the batteries in my 7542 scale and it keeps showing err or Lo. What can I do?
have you replaced the batteries with duracell or energizers? I ask this because sometimes when it comes to this type scales using a lower name brand type of battery isnt strong enough for it or there just may be a malfunction in that product. Let me know if this helps and good luck!
Kenmore Washer
all such appliances have independant hight adjusting 'feet' take some weight off the corner(s) you wish to raise or lower and give the little rubber 'foot' a turn or two clockwise or anticlockwise
Top Taylor Health & Beauty Experts
ZJ Limited
ZJ Limited
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
