Question about Stanley STA-J45C09 450 Watt Jump Starter with Compressor
Stanley fatmax 450
The compressor has stopped working after 1st time I used it.
coatings35
    New Friend:
    Problem Solver:
  • 11 Answers
Open up the case and look inside. A wire may have come off.
i had a brand new compressor that wouldn't power on. A wire was not connected. After reconnecting and a positive testing I put it back together. It ran for five minutes and stopped. It turns out the wire was too short (factory install) and came disconnected each time the compressor was turned on due to the vibration. I rerouted the wire so it wasn't so tight. Problem solved.
Posted on Sep 14, 2017
5 Related Answers
mpservices
  • 191 Answers
SOURCE: How to basically operate my
Press the red button - (distance) you will see a red dot on the wall you are measuring - then you will hear a beep - release the button and read the display - the measurement should be displayed and accurate within a quarter inch.
Posted on Nov 23, 2008
Anonymous
SOURCE: Just purchased a Stanley FatMax 10-778 retractable
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Posted on Apr 11, 2010
Testimonial: "Thanks so much!"
puertobori
  • 7733 Answers
SOURCE: Just purchased a Stanley fatMax
Some models has 2 screws on the knife case.unscrew them and you can access to the blade.
Posted on Nov 08, 2010
lstimo
  • 27 Answers
SOURCE: I cannot figure out how to put a blade in my
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Posted on Apr 21, 2011
jason_duchak
Javva
  • 7 Answers
SOURCE: Loading instruction to change blade on Stanley
Hmmmmm.... that sounds really confusing.
Better yet... just watch this video! http://www.youtube.com/watch?v=B8Q1p-8jkyE
It's actually pretty easy! :)
Posted on Jul 31, 2012
How do i recharge Stanley fatmax 700
You will have to buy charger for Stanley fatmax 700 it will cost you around 12$ to15$. You can buy it from any online shopping website like eBay or any other.
Jun 17, 2018 | Stanley Measuring Tools & Sensors
Stanley fatmax powerit backlight will not turn off
stanley fatmax jumpstarter 1000A light wont turn off?
Nov 26, 2017 | Stanley Measuring Tools & Sensors
Stanley Fatmax 450 Amp (Model J45TK)compressor starts and then stops right away. The charge is full showing the green LED light on.
You will likely have to open up the case to look inside.
The main components will be a circuit board, a 12v power supply, a 12v air pump and a 12v rechargeable battery. It sounds like a loose connection on the air compressor pump. When you turn it on it normally vibrates and is loud. This may be enough to shake loose a wire connection. If so it should be an easy fix to crimp or solder.
Aug 29, 2017 | Stanley Vehicle Parts & Accessories
How can I calibrate a FatMax digital level?
Mark, Automatic calibration, check the little pockets on case instructions inside, the instructions show how.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Stanley FatMax Digital level mp4
Stanley fatmax digital level instructions Measuring Tools Measuring Tools
STANLEY HAND TOOLS Measuring Leveling Layout Levels Stanley FatMax Digital...
http://www.microprecision.com/equipment/STANLEY-CALIBRATION.html
Mar 04, 2016 | Measuring Tools & Sensors
I brought a stanley fatmax retractable knife, have no idea why the blade is not coming out, trying to figure out if i did something wrong like putting the blade in the wrong spot.. this is the only time...
Are you using Stanley Blades or off brand? Hey, I use off brand but sometimes it does make a difference. Second, make sure the blade slider is clean. If you were cutting shingles, for instance, the tar gets in there and screws things up.. try WD-40 spray it liberally all over the blade slide and buttons. If that doesn't work and you purchased it at a Menards store, I can speak of experience they'll replace it no hassle.
I hope I helped
Jan 09, 2018 | Stanley Fatmax Xtreme Retractable Utility...
Vehicle Parts & Accessories Logo
352 people viewed this question
Top Stanley Vehicle Parts & Accessories Experts
Marvin
Marvin
Lawrence Oravetz
MrFixitSTTL
Are you a Stanley Vehicle Part and Accessory Expert? Answer questions, earn points and help others
