There should be a diagram on the label for 110 or 220v-are you sure the last garage you ran it in was 220-it should only run at one of those levels without re-wiring the motor-cheers Denny
Testimonial: "Thanks for the reply. Yes, the diagram shows that it is wired for the 230. The electrician that did the outlet/breaker change said his meter was showing 240 coming out of the outlet and 230 at the motor."
SOURCE: how to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
SOURCE: How to wire a 1dgv1 speed control to a 1tdu8
You will wire this just like a single pole light switch, take your power from your panel (black) to one of the pigtails or set screws and then take another black wire leaving the speed controler to your blower motor. Take the common/white wire directly to the blower, polarity sould not matter which leads you connect them to in the blower.
SOURCE: wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
SOURCE: put dayton split phase 1/2
look carefully at the label!!!. there is a diagram on how to reverse the rotation.
