Question about RCA CC-432 Camcorder
I was given an older VHS camcorder RCA Model #CC423 did this come with an Ac Dc converter if so is there a model # on the converter so I can purchase one?
Posted by steve on
3 Related Answers
techman007
Lavell Turner
  • 1112 Answers
SOURCE: camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Posted on Dec 27, 2009
Anonymous
  • 44 Answers
SOURCE: Need Manual for RCA VHS Camcorder Model No. CC 285
TRY THIS .GOOGLE Manual for RCA VHS Camcorder Model No. CC 285
MAY NEED A BIT OF SEARHING
IF YOU FIND A PDF VERSION,DOWNLOAD IT,AND BURN TO DISC
KEEP IT SAFE RUN IT ON COMPUTER OR PRINT IT OFF
Posted on Feb 15, 2010
Anonymous
  • 26 Answers
SOURCE: I have borrowed an old
It sounds like one of my older, been-in-storage for awhile, camcorders. When they sit for without being used fairly regularly, there is often a bit of dampness that settles into the camera. If left in a warm room, this may help dry it up and allow the open/eject function to work. To help it get un-stuck, you could gently press inward on the door (do not pry outward) and try to loosen it up. It may take a few times with this process to allow the door to jar loose.
Posted on May 16, 2011
Sharp camcorder VL-L285 Troubleshoot
Any VHS camcorder is probably at the end of its life by now - replace it with something more modern
Jun 03, 2017 | Sharp Video Cameras
How do I connect my panasonic vhs 188 camcorder to a dvd recorder?
On these old models of VHS camcorder, I recall they have either RCA outputs, or BNC connectors which will require a BNC adaptor (to convert to RCA).
Using a 3RCA lead, connect the camcorder to the video (and audio) inputs of your DVD recorder.
Sep 19, 2011 | Panasonic AG-188 Camcorder
I have borrowed an old rca vhs camcorder inhopes of converting 4 vhs tapes to dvd. I have a Pinnacle systems DVC 90 to plug from RCA to Computer. I cannot get to cam to open? I charged the battery but...
May 15, 2011 | RCA CC-439 Camcorder
Feb 15, 2010 | RCA Video Cameras
How would i upload live footage from and old camcorder, rca cc4352
They make a usb to rca converter box, that comes with a program. Do a search on camcorder vhs to dvd
Nov 23, 2009 | RCA CC4352 Camcorder
Need part
I had one of those and it was so out dated can't get parts. My battery burnt out and could not find a replacement.
Mar 14, 2017 | RCA CC6151 Camcorder
I have a JVC DR MV7SU DVD/Video recorder. How do
If your camcorder allows you to connect to a tv or vcr and allows you to record from it to the camcorder via the rca video input, then you should be able to record it that.  The camcorder must have the RCA audio/video inputs on it to be successful.
enov8
Mar 08, 2009 | JVC Televison & Video
No power is supplied
More to the point, why was your little child using 'shears' unsupervised ?
Mar 08, 2017 | RCA CC4393 VHS Analog Camcorder
RCA camcorder CC4352 damaged DC cable
My son has the same model camcorder so we are taking turns using the DC cable.
Sep 16, 2008 | RCA CC4352 Camcorder
System down with message "Lithium Battery Only"
Yes, I have seen this problem in the workshop. The problem is not with the battery, but with your camera.
The automatic AC-DC switching cct of the DC-DC converter is faulty. Depending on the model of your camcorder ( I think you have one? ) this could either be quite a cheap repair or more expensive than a new camcorder.
A older model would most likely not be worth repair.
Sorry about the bad news.
Dec 26, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
RCA CC-432 Camcorder Logo
Top RCA Video Cameras Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
