Question about Yahoo YDP-700 Portable DVD Player
Need external battery pack for Ferguson LDVD81
1 Related Answer
Anonymous
SOURCE: i need a new battery pack for LDVD81
hope this helps.
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=1144398&brand=&model=ldvd81&part=
Posted on Nov 19, 2009
Poloroid spectra 2........Does it have a battery, and how do you get into it???
The battery is included in the film pack. All original film packs now have flat batteries, especially if cold stored. Refrigerated packs with flat batteries can be used if you convert the camera to accept an external 4.5v dc stabilised power supply such as an external battery pack.
New film packs are available from The Impossible Project, but they are not the same material as the original Polaroid ones. The website tells you about the differences in results and product behaviour.
Jun 13, 2011 | Polaroid Spectra 1200si Instant Camera
We have managed to lose the rechargeable battery pack. Where can I get another one?
Oh my, not good. Well, you do need a battery pack. Contact the MFR for replacement pack via customer support, or check the voltage on the side, if using 9V, get a battery holder that uses 8 batteries[2 Xtra cells are used to disable the shutting off at too high a voltage due to the missing battery pack]go to battery space.com, and go to wires/connectors, and get the laptop connectors to make an external battery pack. Therte is a battery pack charger/I recommend accupower evolution. You have to google and go to other sites to get the rechargeable batteries and battery holder. You can get by with alkaline, but they would go rather fast due to the large screen size. You need that good brand name so they can be evenly charged due to the batteries being able to be run down further. You wont be wasting much voltage with alkaline due to the lower cutoff voltage, but 1st try contacting the mfr or googling to get that battery pack!!!I Hint: if using battery pack and you still want to add more battery life, drop the batteries to 6 on a 9V circuit. with original battery pack on, a 9V circuit would use 6 D cells on an external pack, 8 for a 12 volt.
Aug 17, 2009 | kawasaki PVS-10921 Portable DVD Player
Battery is dying
Nope - that battery is completely rechargeable. There is a small possibility that the battery could have experienced some small corrosion, but this is a slim possibility. The documentation suggests that this model has an external battery pack, and comes with the following instructions:
Slide the external battery pack cover to open it.
Insert four AA batteries, be careful to observe the correct polarity. Slide the
cover back into place.
Inserting external battery pack
Twist the external battery pack to UNLOCK direction. Insert the H300 to the
system slot of the external battery pack.
May 31, 2008 | iRiver H340 MP3 Player
My ferguson ldvd81 it shows loading disc but that is all does not play anything
The reason the player will not play a disc is probably because the disc is not spinning. You need to power up the player and leave the dvd door open. Then push in the little switch that is normally operated by the dvd door but make sure you do not look directly at the laser. You should see the logo on the screen saying loading but the turntable is probably not turning. If this is the case, then the most likely cause is that the motor control chip inside the dvd is blown. This seems to be quite a common feature of these type of players.
Apr 16, 2008 | Televison & Video
External power battery pack
No. The EBP-100 is not usable, and we cannot guarantee compatibility with any other manufacturer's external battery packs.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
What is the external battery pack "EBP-100"?
This is the external battery pack used for the DiMAGE A1, 7, 7i,7Hi, 5, S414, S404, S304, Z1, Z2 and A2. This is the type of external battery pack that connects the camera and the battery part with a cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Two lithium batteries NP-100 Approx. 480 frames(recording), Approx.450 min(playback) Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Battery Charger BC100 is sold separately. INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
What is external battery pack "EBP-100"?
This is the external battery pack for DiMAGE 7, 7i,7Hi, 5, S414, S404 and S304. This is the type of external battery pack to connect the camera and the battery part with cord. Taking a picture while keeping the battery part only warm in a cold place. As there is a belt loop at the part of battery, it does not bother to capture images. Battery:Two lithium batteries NP-100 Battery performance: Approx. 580 frames(recording), Approx. 580 min(playback) Accessories: Battery Charger BC-100, Lithium ion battery NP-100(2pcs), Battery holder BH-100 Optional: Battery Charger BC100 is sold separately. BC-100 specifications: INPUT: AC100-240V/50-60Hz, OUTPUT: DC8.4V1.1A
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Yahoo YDP-700 Portable DVD Player Logo
Top Yahoo Televison & Video Experts
Lawrence Oravetz
Are you a Yahoo Televison and Video Expert? Answer questions, earn points and help others
