Unfortunately you can't do that. When the phone rings, a signal is sent from the telephone exchange to your handset with the number. The phone will maybe put dashes ( - ) in the number, as you've written, but it will only display the data it's given.
To verify this - maybe try the phone on someone else's line (who would need to have caller ID enabled, of course) - also, you could find another handset (with Caller ID) and see what data is displayed on there.
Good luck. :)
SOURCE: Transfering incoming phone calls Mod. Panasonic KX-T7730
do you mean call divert?
its possible.
we could do it.
SOURCE: How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
SOURCE: New Voice Mail message
You received a message on the voicemail system provided by your telephone company. To hear the message, dial the voicemail number provided by your service provider (in many cases, this will be your own phone number), and follow the voice instructions for listening to your messages. You need to store the voicemail access # by pressing [MENU], [#] [3],[3],[1] on the handset. To access the voicemail, press [TALK], then softkey [VM]. Depending on your service provider, you may need to clear your voice mailbox to remove the notification.
SOURCE: We have a Panasonic cordless
We have a Panasonic XK-TGA402 and are having difficulty setting up the call answering service. The manual that came with the unit doesn't match the model number and we're wondering if the instructions in the manual are missing something. Anyone help?
SOURCE: download user manual for Panasonic phone kx-tga402
You may download a copy of the manual here.
