Could be the error has nothing to do with the rain at all. The camera is perhaps 4 years of age? some batteries last for 10 years. But some can't survive 2 or 3 years. All depends on how they were used or abused. When normal charged and discharged in a regular cycle, the battery can survive 1000 cycles. When left alone for very long periods it damages the battery. See if you know someone with a Nikon camera that uses the same battery and try his battery in your cam and put your battery (if he or she allows this) in the the other camera. If another battery works correct, no need to test your battery in another camera.
You also could look in the battery compartment is the connection points are corroded by the water. ls check the contacts on the battery. Eventually clean it with contact fluid. don't scratch the contacts, because the will corrode very quick after that.
Testimonial: "Thanks so much! I will try your solutions!"
SOURCE: how to remove the battery from nikon d3000
the little trap door on the bottom houses both the memory card and the battery. you have to push the battery slightly to release it. i fond the easiest way at that point is to tip the camera and the battery usually slides right out.
SOURCE: I put new batteries into my nikon camer after I
your batteries may not be compatible with thecamera, you should use En-MH2 batteries... en-MH1 are not compatible with l100 try to use these ones... http://www.nikon.com/about/news/2009/0609_mh-73_en-mh2-b4_01.htm
SOURCE: Nikon D3000. Exposure lock with focus problem.
Probably your lens causes this I think. Please check these.
1. Your lens may cause this. Change it and try again.If you do not have another lens then go on to check the next instrutions.
2. Check your lens AF button. It should be switched to AF.
3. Turn off and on the camera and try again.
4. Check your battery charging.
5. Your lens should be cleaned complitely. Please check its clearity.
I think it will work. But if it does not work properly again then your camera should be checked.
Clean your camera mirror. For this:
1. Turn off your camera.
2. Remove your lens.
3. Clean your mirror without using water or any other liquid or any other chemicals. Use only special cleaning liquid that is made for lens cleaning.
4. If it does not work then your camera body should be checked electronically and mechanically. This check can only be done with an authorized service tecnician. So you should send your camera to your service dealer.
SOURCE: Nikon D3100 brand new. I
The fault could be either defective batteries or a defective camera. All you can do is to try a full initial battery charge (24 hours) and if that doesn't work return the camera to the retailer for a refund or exchange.
SOURCE: I want to print a picture from a nikon d3000 using pictbridge on
you could read it on p.107 - p.114 at your Nikon D3000`s user manual books
thanks
