Have you seen this video with advice?
http://www.benchfly.com/video/41/removing-a-stuck-centrifuge-rotor/
Another tip is to cool the rotor down (either by getting the refrigeration to kick in if it is a refrigerated centrifuge) or perhaps by filling the the rotor with tubes full of ice-water (or something colder...). Everything will shrink slightly, which means the rotor will become a slightly looser fit on the shaft.
SOURCE: How to replace front rotors
You'll need to take the wheel bearings off. the rotors are bolted to the hub and the bolts are located in the back of the hub thus having to remove the wheel bearings and removed the hub/rotor assy.
SOURCE: Low engine idle speed when the air conditioning is running
the ac idle assist may be defective, if it's electric check the fuses if it's vachum operated check for vac. leaks. Also lube cables sometimes they stick Use wd-40 on the cables sparingly don't want dirt to stick to the cable.
SOURCE: dyson dc17 animal motor spindle keeps clogging
If you have animals get rid of the dyson and go to a vacuum that has a metal brushroll and better airflow. There is no fix on the dyson they just are not good on hair of any kind.
SOURCE: Panasonic Inverter CS-E12EKU timer indicator blink.
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
