SOURCE: Lost Remote Control
Do a google search for "emerson remotes" (in quotes) and take your pick. I have ordered them by model number from Fox International at 800-321-6993.
SOURCE: spongebob remote
Contact Emerson Electronics customer service to acquire a replacement remote for this set, as this set does not have the extensive circuitry inside to duplicate the functions of said remote...accordianman
SOURCE: Picture is Tilted
The quickest correct fix for this problem is to open the TV, turn it on and display something on it. Then, on the the neck of the tube (where the screen just thins out) you'll see a an assembly of coils and odd disk-shaped objects. These are really magnets - the coil being the scanning or deflection electro-magnets and the disks being low-strength magnets. It is likely that with age the positioning (called alignment) of these have changed slightly to giving rise to the symptons you describe. Taking care for shock (keep your left hand in your back trouser pocket) try rotating this coil array while observing the picture, which should rotate accordingly (keeping a large mirror in front of the TV would help much). Once you are satisfied with the picture, you can use a glue-gun or even sellotape to secure the assembly from drifting again. Then switch off your TV, put the cover back and ENJOY your handiwork!
SOURCE: Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
SOURCE: emerson 13 in later model tv
rca universal system link4 remote is very good.check canadian tire
code for emerson 038
