I have a kitchen aid oven ykerc507hs2. I bought it in 2000. One of the elements on the top is a dual one. I can use either the whole element or just the middle part. The problem is whether i turn the dial to low med or high the element only stays on high.
The trouble would be a failed infinite heat switch. This is the adjustable switch you are using to set the element to low, medium or high.
**Use extreme caution if you are making the repairs yourself.....Turn off circuit breaker and verify power is off with a meter. 240VAC is present at the switch. In addition, the glass top and elements are very fragile.
