The GPU in every laptop is soldered in place, if you have a lot of experience with reflowing then you can try to pull the GPU and replace it but a lot of the time it's actually more cost effective to get a replacement MB and sell the one that's having issues. Because the GPU may not be the only part that has gone out or it maybe another part that has gone out and is keeping the GPU from powering or outputting signals
Testimonial: "I wish I would have taken pictures of it before I put it back together to show what I am talking about. Am I looking at the wrong thing then as it is not soldered to the motherboard, you can use a quarter and unscrew the housing from the GPU. Maybe I am just confused. Thanks for the input"
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive you should have no input while chkdsk utility is in progress any input might further damage your computer or Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. hope this helps
Please select an option:
Safe Mode with Networking
Safe Mode with Command Prompt
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
SOURCE: what motherboards fit a toshiba
V000185540 Click on this link or copy and paste the complete link into your browser. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
Laptop Motherboard: MAIN BOARD; RS880MC
$268.00
V000185210
Laptop Motherboard: MAIN BOARD, RS780MC 2
$437.50
V000185220
Laptop Motherboard: MAIN BOARD, RS780MN 3
$308.00
http://www.sparepartswarehouse.com/Toshiba,Satellite,L505D,Laptop,System-Boards.aspx
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Can I connect my LG
Ok in order to hook up the laptop to the TV you have 2 options
First option.
Buy something like this
http://www.amazon.com/Sewell-Converter-All-One-Cable/dp/B003BVVYSM it will directly interface your laptop with your tv. The benefit will be you will get sound to your tv from the laptop
second option.
you will need a vga to hdmi cable like this one
you can buy this here
now this option will only let you have just the video from your laptop on the television because a VGA cable is a video only cable and port.
I hope this helps you.
