Question about Sony SLV-D380P DVD Player/VCR
Cannot program vcr.. It always says"wait a moment" or something like that..I powered off and on. I even unplugged it. I have two other sony's vcrs. Which are the same model that are having the same problem
Posted by Wild Bill on
Jim Stephenson
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
Contact factory.
Posted on Oct 29, 2013
Sony SLV-77 is loosing the program every power
Have a look around inside for something that looks like this:
5ae3773.jpg It's a memory retention capacitor and it's used to store a charge which will keep an IC with power when the device is not connected to the mains. When they go the effect is the same as what you say is happening. They often have only that 5.5 volt rating so are easy to spot compared to normal capacitors. They are not expensive either!
Jun 07, 2010 | Televison & Video
Sony SLV-775HF issue (power off, freeze, digital cable related?)
These guys have the owners manual and the service manual for your exact model; http://www.user-manuals.com/advanced_search_result.php?keywords=sony+SLV-775HF+manual&forward=plist&osCsid=a4cf756dbc2b6f254269ca22308687e5 Sorry I haven't been able to locate these for free anywhere, Sony do not have them available online. Here is the link to the Wow cable instructions - i couldn't find much in there but you may see something that helps out, check pages 65-67 to be sure you have everything hooked up right; http://www1.wowway.com/cable/pdf/WOWGuide.pdf Here is the link to the user manual for the explorer 3200; http://www.scientificatlanta.com/products/consumers/new_explorer2200.htm and here for the FAQs; http://www.scientificatlanta.com/products/consumers/FAQs.htm Hope this helps, if you get some more ideas but still no solution, please post back and i can try again :)"
Jan 28, 2007 | Sony SLV-775HF VCR
CAN NOT INSERT A TAPE WHEN POWER IS TURNED ON
Sony VCRs have shown these error codes for years whenever a problem occurs but it really does not help much to know what the code means. Even if you knew the code meaning you still would not know exactly what to fix in the VCR. Suffice it to say the VCR probably needs repair.
Go to https://eservice.sony.com/webrma/web/index.do
and enter your zipcode to locate a SONY repair facility.
Apr 28, 2010 | Sony SLV-775HF VCR
Sony - SLV-685HF -vcr using universal remote one for all 3021 can't change recording from sp to ep so I can record more on tape. vcr says auto, or 180 in speed setting always records sp. I just want to pop...
I solved it myself by selecting guide on the remote, then the tv screen said enter plus code. ijust type in all 0's for each space given (0000000) then the setting instantly changrd to EP from SP. I pushed set on the universal remote , that was it.
It was necessary to use the power button to turn vcr off like tthe TV screen said because I was just setting the timer. You can just go to menu or whatever next.
I didn't appreciate FixYa trying to sell me a membership before even
attempting to offer a solution. They could have at least faked trying to find a solution. Instant response we would like to offer our premium services ....
Jan 18, 2010 | Sony Televison & Video
VCR dead after pulling plug from socket
Try holding the POWER switch down while plugging in the power cord. Craig
Nov 23, 2009 | Daewoo Televison & Video
Remote ineffective.
If you have a video camera with a night vision setting, wait until dark, turn out the lights and turn the camera onto night vision and look the the remote. When you press the buttons on the remote does the small led transmitter on the front ligh up. If so the remote is working but possibly sending the incorrect signals.
Jan 22, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-798 HF VCR
on alot of vcrs if you already have a set time for one channel to record at a later time if you dant set the earliest first it wont let you change it but im not sure if you already have one set ahead of time or not
Feb 09, 2008 | Televison & Video
Pioneer DVR-633H-S hard drive problem
do the Reset to factotry settings,hold two buttons same time {STOPand STANDBY}on front off your unit and unplaged the power from the wall same time.wait like 5minutes,and pluged back the power,this my work,did work for me.
Dec 10, 2007 | Pioneer DVR-633H-S
Won't timer record
- Does it have a tape inserted?
- Is the clock set?
- Is VCR off? (has to be off to be in timer mode for many VCRs)
- Is it recording but just plays back blank or does it not even start?
- If recording blank, make sure you are giving it a signal (Is your monitor hooked to the VCR output?)
- If timer doesn't start double check timer settings - they can be very tricky.
Nov 06, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-D380P DVD Player/VCR Logo
49 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
