SOURCE: drum reset for Panasonic kx-mb781
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
SOURCE: Panasonic KX-MB781 drum reset
I already answered this at some other place her - but here I go again: There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
SOURCE: hi ihave a panasonic kx-mb781 and it say on
Fuser unit cannot heat up. Replace fuser unit.
Refer to CALL SERVICE 3 (P.120).
SOURCE: how to reset the drum on a panasonic kx-mb781
How to disable the COPY option of KX-MB781 all in one laser printer?
