Sennheiser PMX 60 Consumer Headphones Logo
A
Anonymous Posted on Oct 29, 2013
Suddenly, Right side of the Sennheiser PMX 60 does not give any sound. Left is fine. Today morning I opened up the ear buds and found the wiring is fine for both sides. Can this be repaired and I hear sound in both the ears. Please help.
2answers
Why no more sound in left side? the right side is fine. i moved the left side like a seesaw, then i found where the sound occur. is it the wire connection problem inside the left side? what to do?
Opened up one of the earcups and dont ask me how it was just by force. The cable that connects the 2.5 to the speaker is frail and there is quite a bit of shielded cable that can rub against each other over time. I fixed it by removing the cable and soldering in two separate cables of similar size.
2answers
Jvc gumy ear bud headphones purple
When you pull the wire up does it increase the right ear bud volume/ sound? If it does, then it means the right side ear bud has a short within the head phones circuit which is aka the wire that leads to the musical device in which the ear buds branch off from.
If the right side ear bud does not produce an increased volume for sound by picking the wire up or pulling it in towards you or to the left side of your body or musical device then it means that the right speaker is blown.
I know that all head phones come spiced together aka they are stuck together and have to be pulled apart in order to get both head phones seperated from each other so that they can be worn in the ears. If you pulled the wire apart to much or too quickly then that is what ruined the right head phone.
I suggest that regardless if the ear phones begin to work by pulling the wire up,side ways, or into towards your body that you return them back to the store since after awhile the problem will eventually continue to happen causing the right ear bud to completely blow. Once you return the ear phones be cautious with the new set when you seperate the ear buds from each other since they are very touchy and have to be handled with delicateness when seperation is taking place.
Please let me know how it works out for you. I have had many ear buds and I tell ya something; they are very easy to blow one side when seperating. I had to learn after a few pairs that I was ruining the speakers by the way I was seperating my wires. I kept thinking for the first 3 pairs that the store was selling blown ear buds until I began having same problems with another few stores so I said to myself "well the solution is to figure out what I am doing wrong in order to blow one side of my ear buds every time". After few seconds it was not that obvious that all I had to do for assembly was to pull the wires apart in order to get both ear buds to go into my ears.
Sennheister RS120 head phone left ear no sound
Dear friend ,
try to check wiring connection by opening tic tac locks of left side. If there is loose connection solder it .
9helpful
2answers
I need replacement ear pads for the pmx 680
  • You can get replacement parts here.
  • Please reply if you have any more questions. Good luck! (Please give a thumbs up, I am doing this for a summer job!)
2answers
Require new ear pads. The black is cracking off
You might want to take a look at my Tip on headphones, right at the bottom of it. Just click my user name to find it.
4helpful
When I used these headphones this morning, I noticed that the sound from one of them was far less powerful than the other one. I've tried different songs, to see if it wasn't just the song, but the problem...
had the same problem with the right ear bud and I don't know if it is suggested in the manual, but cleaning the mesh on the ear bud with a cotton stick dipped lightly in alcohol (almost dry) helped with me, the sound is back 100%.
I hope it helpes with your too.
Mykab
3helpful
4answers
Top Sennheiser Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
