Question about Nokia C5-00
Plz help nokia c5-00.2 bsi ways - Nokia C5-00
Posted by bishal rai on
Altaf hussain sofi
    New Friend:
C5 oo bsi print miss plz help me
Posted on Apr 17, 2014
How can i get my security code I forget it? nokia model:106.1 type:rm-929 is there a way?
No way unless it's flash unlocked. Take it to your nearest technician. It's very cheap and takes just a couple of minutes.
Jul 20, 2014 | Nokia Cell Phones
I have a nokia 3110c and he gives empty battery during his call and turn off plz send me any solution abou it.thanks advance
Hi. Here is the first Aid.First remove the battery and clean the Center Terminal (BSI line) of the battery.Secondly check the battery whether it is Original or Copy.If the problem still ,After you have cleaned the center terminal and the battery is noticed as original you need to contact mobile tech to check internal problem.Good luck Thanks for visiting fixya
Sep 26, 2011 | Nokia 3110 Cellular Phone
NOKIA 1280 WATER DAMAGE STE DEAD
Aug 14, 2011 | Cell Phones
After flash nokia 6300 by using JAF software. my phone is dead and not detect USB ...... plz solve my problem which type of software i hve to use for flash my mobile n also tell the solution for my dead...
Do you mean it's dead right after the Flash or while flashing? If it's dead after successful, you'll need to re-flash it, in the same way, if it was dead while updating, you will still need to re-flash it. But things you need to note before flashing, make sure you have the compatible flash file installed i.e. RM-217, latest version recommended. Reconnect the phone to your Jaf Box and make sure it's detected in it's Local Mode, if so, you will be able to flash it without any problem. If it's not, then there must be hardware failure eg, damaged ROM or Cpu failure or power supply issue (not likely if the problem started only after it was flashed). It's also important to note the condition of the handset before it was flashed, suppose if there was hardware issue (for which you tried to flash it), then it's possible that the hardware fails to function anymore (just in case).
Have you tried charging it when it's Off? If it's ok, then do you see any message on the screen, eg. Test Mode or Contact Service (perhaps these messages might display in dark screen mode).
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jul 19, 2011 | Nokia 6300 Cell Phone
My nokia 1209 not charging and showing local mode plz help
The solution of Not Charging in 1209,1200 etc. can solve easily.It is same as the the solution of Local/test mode but it comes mainly from some sort in BSI line.So try this.....raingamj.jpg
Mar 21, 2011 | Nokia 1209 Cell Phone
2003 ford explorer is stuck in park, the brake lights are on so i dont think it is something to do with the brake
adobe.gif Printable View (109 KB) TSB
04-22-12
  • GEAR SELECTOR LEVER - INCREASED EFFORT TO SHIFT FROM DRIVE TO PARK
Publication Date: November 1, 2004
FORD: 2002-2005 Explorer, Mountaineer ISSUE: Some 2002-2005 Explorer 4dr/Mountaineer vehicles, may require a greater effort to move the gear selector lever (shift lever) from drive to park. This may be due to a time delay with the brake shift interlock (BSI) pin retraction.
ACTION: To service, replace the BSI switch. Refer to the following Service Procedure.
SERVICE PROCEDURE
  1. Remove the two (2) fasteners supporting the instrument panel knee bolster from below the steering column and remove the cover (Figure 1).
    Figure 1 - Article 04-22-12
  2. Remove the three (3) fasteners supporting the steering column lower shroud and remove the cover (Figure 2).
    Figure 2 - Article 04-22-12
  3. Remove the three (3) wiring bundle carrier fasteners from the bottom of the steering column to allow movement while removing the BSI switch. It may be necessary to release the connectors from the multifunction switch (Figure 3).
    Figure 3 - Article 04-22-12
  4. Remove the BSI fasteners (T-30 on the side and T-20 on the bottom) (Figure 4).
    Figure 4 - Article 04-22-12
  5. Pull the BSI tab on the bottom of the column downward to help free the BSI from the column housing.
  6. Break the two (2) side tabs off the BSI by the white wiring connector (Figure 5).
    Figure 5 - Article 04-22-12
  7. Push the locking tab on the white connector towards the wiring to release the connector from the BSI. Be careful not to damage the connector or wiring. If the connector does not free easily, a very small flat screwdriver may be used to help lift the locking tab (Figure 6).
    Figure 6 - Article 04-22-12
  8. Connect the wiring to the new BSI. Ensure all clips are fully engaged to prevent the connector from pulling free.
  9. Reinstall the BSI onto the steering column and reinstall fasteners (Figure 7).
    Figure 7 - Article 04-22-12
  10. Check BSI function. With the key in the accessories or run position, press the brake pedal. The BSI pin should retract on brake application, and spring up one (1) second after releasing the brake pedal. Repeat several times.
  11. Reinstall fasteners to connect wiring bundle carrier to the steering column. Make sure all connections to the multifunction switch unit are secured properly.
  12. Reassemble steering column in reverse order. Ensure rubber gap hider around shift lever is properly seated on the shroud.
  13. Cycle the shift lever from park to drive and drive back to park several times to verify improved shift effort.
PART NUMBER PART NAME 1L2Z-3Z719-DA BSI Switch
Feb 15, 2011 | Ford Explorer Cars & Trucks
Nokia 2700 classic security code forgot
i forgot security code of my nokia 2700 classic mobile,is there any way to reset or any other solution,please help ,
May 25, 2010 | Nokia Classic 2700 Cell Phone
My nokia 6280 is not keeping gharge and is refusing to charge
1-Try another trusted genuine battery.
2- Try another trusted genuine charger.
3- If RETU IC is not under-filled try yo reflow it, if not works then replace it.
4- No way but to try replacing TAHVO IC even if it's under-filled (if you really want to solve the problem) ;) .
maybe ur bsi line short to ground!!
try to remove the resistor in bsi line....
Mar 21, 2009 | Nokia 6280 Cellular Phone
Nokia 6600 problem
The only way, is to inject a short pulse on the BSI terminal, its the center terminal on the battery connector. But you need an electronic pulser to do that. It's better to have the switch replaced, it wont cost you a lot.
Apr 08, 2008 | Nokia N80 Cellular Phone
Nokia C5-00 Logo
391 people viewed this question
Top Nokia Audio Players & Recorders Experts
Vernon Taylor
Harrie
ray gallant
Are you a Nokia Audio Player and Recorder Expert? Answer questions, earn points and help others
