Motorola GP300 Compatible 2 Way Radio Battery Eliminator Logo
A
Anonymous Posted on Oct 29, 2013
MOTOROLA GP-2000 SCHEMATIC Diagram - Motorola GP300 Compatible 2 Way Radio Battery Eliminator
1 Related Answer
Anonymous
  • 123 Answers
  • Posted on Feb 04, 2010
SOURCE: Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Testimonial: "Thanks for the response. appreciated it. It is very useful."
General Pump "T 47 Series" TS1321 2100psi 4.75gpm. Schematic or diagram for GP T series 47 TS1321.
Question edited for clarity.
Question moved from Cars and Trucks, because it isn't.
help in the link, plus access to the maker.
https://www.google.com/search?q=gp+t+series+47+ts1321+schematic+diagram
T-con V500DK2-CKS2
May want to send email question to a seller to see if they have the schematic to sell with the board.
For example:
https://www.amazon.com/gp/offer-listing/B01N0SW98Y
Amazon com Seller Profile GTV Parts
3answers
How to repair weak signal motorolla gp 2000
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
1helpful
2answers
Motorola gp2000 clonning cable wiring diagram
Check your squelch level first try to adjust it, if this didnt fix the problem, re solder or replace your filters, the semi rectangular (color black) "TOKO A55, B55 those filters are covered by a rubber
12helpful
2answers
Motorola gp 63
The GP-63 and the GP-68 uses the same users manual. You can download the user manual which also has programming and cloning information in it from:
http://www.batlabs.com/2way.html and choose GP-63......Good luck
HOW TO OPEN FREQ
you need to have the radio programed with motorolas rss program.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
