Question about RCA 27F534T TV
I cant put my rca TV on video - RCA 27F534T TV
1helpful
How can i put a hmdi cable into my goodmans gtv42p tv
then you TV is not equipped for HDMI but u can use Component cables they work just as well. on back of the TV you should see several plug in's the RED,WHITE and Video are called RCA , they will work too. but the next one u look for are labeled Comp. (purple, red and green) they are larger and thicker that the RCA , plug those into you Satellite receiver or Blu Ray Player. Then go to ur TV and view it using the matching video stream..
How do i hook up the ps2 to my tv
you can connect your PS2 on tv by using video RCA... connect the fort on at the back of you ps2 and connect the three rca to your tv yellow colored for video, white and red for your audio... tnx
Have a rca TV AND RCA REMOTE BUT CANT GET IT TO VIDEO 1 TO PLAY DVD
Hi, If your TV and player have : AV1, AV2, S VIDEO, HDMI; you can test one by one the connection to get them work. May be some of them unable to works.
Regards,
When I turn on my wii all I get is a black screen. The Wii is on but the main menu wont come up and I cant see anything.
Make sure you have the yellow video RCA cable in the right slot. You may have it in an HDTV slot or a output slot on your TV. Make sure you put the RCA (Red/Yellow/White) cables into the standard input RCA slots.
S-video on my tv
s video is some times refered to as yc in the menu
Videos
RCA Opal 4001/4002 – Transferring Videos
You will need to download the RCA Media Converter from RCA's website, and then convert the videos before they will transfer to your player.
-Tha Mp3 Doctor
1helpful
2answers
Cant find set up screen
the system is not easy and I have had the same problem with my moms. The one thing I know is you have to be able to get it in the setup mode for anything to work correct. If you are using the rca jack outputs in the rear (e1 is the dvd vhs video and audio out and e2 is on the front of the box and that is for video and audio in) you have to hit source and put it to e1. When you hit source on the remote it will go from tv I believe it will say channel 3,hit it again it goes to e1 and then to e2. If you are using the cable in and out put the source to tv or ch3. to record from vhs to dvd you have to push the button on the front I believe its called dubbing. It is the only diffrent colored button. This automatically sets it up you should be able to watch the video being recorded while it is recording to the dvd. Make sure you have the correct type dvd I know the +R work. It is very important to get the setup done and that is the hardest part to get too. Also remember if you are using video out(rca jacks) you must switch your tv to video in and if you are using the old style cables you set your tv to ant1 or ant 2 depending what input you are using. The problem with this is having to know your tv and what source you have set on it, ant1 or ant2 or video 1,2,or 3. It all depends on how you take the video and audio out of the vcr/dvd player. Once again if you use rca jacks you must use the remote source button and put it to e1 and then put the other end of the jacks to video input of the tv and change the source on the tv to video also. If you use the old cable in and out you must change the source on the vcr/dvd remote to ch3 and set the tv to ant 1 or 2 depending on how may inputs you have. you must match the systems. Hope this helps
Cant get picture on 56' tv from my laptop
connect your s video then using your remote press remote key "input"> your s video is label vid 1 this should get your video flowing
My tv and dvd
try to check your connection if your video cable is hooked up in the right place for video. probably you connected your video in the other input or you put it in the output connection. also check your cable. good luck!
RCA 27F534T TV Logo
Top RCA Televison & Video Experts
 Francisco Mauricio...
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
