Samsung RS2534 Freezer works but refridgerator side doesn't cool. I held the two opposing top buttons in on the door - it showed a problem with the fridge side. I took the panel off the inside in the back of the fridge side. Coil was a block of ice. I melted with a blow dryer and dryed and reassembled. Temps. came down on both sides quickly and fridge seemed to be fixed. Did the button test and no fault came up. Went to bed happy. The next day I pushed in the two buttons and it's still showing a problem with the fridge side. The fan motor on the fridge side is working but I still seem to have some sort of problem.
Replace the sensor and the main board
Generally this type of problem not come in Samsung fridge, but if you face than try to change the sensor and the main board, I think if there is a problem it is solved after doing that.
Fridge warranty
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
