If your pbx has a built in disa feature, then you need to program
the DIL (sys. pgm. # 418) to DISA-OGM 1. Then you need to
record an OGM (program 9,1,1) to tell you customers that
they can dial the ext.# directly.
Testimonial: "So how do I find out if our pbx has a built in disa feature?"
SOURCE: change the ring tone of Panasonic KX-T7730
I think it can be done. Just exchange the phone for a 7633 and change out the TA for a TDA-50.
Piece of cake.
Carl
SOURCE: Changing the names for extensions
Name changes are done from the System Administrators phone. In the TA-series, it's system program 604. In a TAW it's 004. I can give you complete instructions, but you have to get to that screen first.
If you get there and want to play, the SP Phone FWD CONF MUTE and keypad press up to 7 times enter the Alphabet names (space is under 1). Nothing writes until you press STORE.
Carl
SOURCE: Changing names assigned to extension numbers
I just worked it out.
Press Program
Then **
followed by your passcode (usually 1234)
Then 004
Then press next till you find Mark
Press Shift then the button under Clr
Then enter the name so for Claire start with 2 and swing the jog button round till you get a C, then press 5 and swing the jog button round till you get an l etc..
If you make a mistake press Transfer
Then when you've got your name correct press Auto Dial.
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
SOURCE: panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
