if it is still under warranty you may wanna check their online customer service representative for home service. If not under warranty then you can do DIY as long as you can follow the disassembly steps and as long as you know some basic electronics testing. Look for the pressure sensor switch. Let it check for its continuity through multimeter. This part can be removed on the machine if you dont know how to test then ask your nearest technician to do the testing.
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
This could be a problem in the pump or in the timer circuit, but since you say that it cycles normally I would guess that the drain pump has went out on this unit.
Error code F05 denotes pressure switch jammed on full.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit back and test.
Please rate my solution.
Thgankyou.
Washin machines "do not" have heating devices, make sure to check your water heater and turn it back on to get your water heated.
That will get you back in hot water business.
GOOD LUCK.
Did the problem start directly after the washine machine was fixed ? I wonder if when the washing machine was moved back, the hose to the dishwasher has become trapped and kinked behind the washing machine. Or maybe the supply to the dishwasher is separate to the washing machine and has been turned off by mistake.
Rob, sounds like you need an agitator repair kit. Not a hard job, under the dispenser cap you have a set of ears, spring and plastic bearing. The kit is cheap, you can find it here http://www.repairclinic.com/0080.asp Catriver...post back
