I shut the engine off,went to start it a few minutes later and had nothing,no idiot lights, dome light,no power what so ever.Battery checks good.Strange twist: with door open,there is a clicking sound behind glove compt.,close door,it stops,open door it starts
When the armed Vehicle Theft Security System (VTSS) senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed after the battery is reconnected.
The alarm can be disarmed by locking the vehicle and turning the drivers door lock to the lock (arm) position. Wait a few minutes then unlock (disarm) the drivers door and the vehicle should start.
If the VTSS has been disabled in the high-line Central Timer Module (CTM), the VTSS feature must be re-enabled using the Chrysler DRB scan tool. The clicking you heard was probably from the CTM located behind the glove box.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Check the fuses should be the one that has something like (ign) one of the fuses in that little box can stop the motor and things from working. im pretty sure its the one i stated above.
My head lights will not work and my door locks wont work along with the alarm system for the truck.
Battery was load testsd
Fixed problem by changing ground cable,terminal end,under insulation, copper was very deteriorated
How does the battery check good?
Load Tested or just tested with a DMM?
