Kodak EasyShare C743 Digital Camera Logo
Posted on Sep 30, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens will not extend
Camera turns on briefly, Lens error 20e 1,0,0 shows in the LCD window then the camera shuts off. Also, (when it was operational) it seems to constantly use up alkaline batteries at a *very* fast rate. Are the 2 related?
Anonymous
Level 2:
Champion:
  • Expert 217 Answers
  • Posted on Sep 30, 2007
Anonymous
Expert
Level 2:
Champion:
Answers
217
Questions
0
Helped
103638
Points
312
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
My Kodak easy-share len is stuck. what do this Len error 20e 1,0,0 means?
There are some steps which can be followed which may resolve this problem which as follows,
1: Switch on the camera while you hold the shutter button and connect it to the AC adapter or to the USB cable at the same time.
2: Now by default the lens should get properly aligned if not try to twist them slightly by holding down the camera lens with soft hands.
3: Just push and pull the lens slightly as it extends automatically.
4: Now when the lens is in the hard surface power on your camera.
5: Try to hit the camera softly beside the lens which might solve the issue.
You can try to format the memory card completely and then reinsert to your camera which might be the issue at times.
The camera turns on then shuts back off again
hat type of problem is usually associated with a lens extend error.
It is usually caused by weak batteries or dropping the camera.
Keep your eye on the LCD screen when you turn the camera on.
Do you see any type of error message?
Now turn the camera on again and help the lens extend by gently pulling on the lens as it extends.
Does the camera stay on when you do that?
3helpful
2answers
Kodak easyshare c713 showing lens error 221,0,0,0. what does this mean.
KODAK C713 LENS ERROE 20E 1,0,0?
IT DID NOT RESOLVE AFTER PUTTING NEW FULL CHARGE (AA) SIZE BATTERY EVEN , WHEN I TURN ON CAM IT SHOWS ERROR 20E 1,0,0 AND SHUT DWON.
1helpful
B03 error code on kodak easyshare one 4mp digital camera
THe issue of the camera shutting down and the lens Extending is an internal malfunction. UNited Camera Repair has been able to fix this, at least for me, they did. They replaced the main board and the camera worked when I got it back. Otherwise, if you dont want to spend the money, its a gonner..
Camera will not operate
Use the audio-visual cable that came with your camera and connect your camera to your TV.  Now turn-on your camera and switch to "view mode", e.g., to see a already taken picture on your LCD.  You will not see anything on your LCD but may see an image on your TV, even if the image is "F18".
I used the above trick to clear an F18 error on an A75.  Right now I am trying to get the camera to focus properly, but somehow the above cleared the F18 error.
If the above does not work, try connecting your camera to your computer's USB port using the other cable that came with the camera.  Your camera will want to be on, and in the "view mode".  I have read that this trick can reset an F18 error.
Good luck.  At least it costs zero to try these two tips.
Canon A95 operability issue
Camera turns on then auto shuts down??
when the lens comes out grab it and lightly!!! push it to one side this worked on a cannon i have
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
